OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
ERROR :clBuildProgram (-11)
zkleo
Hi. I'm sorry x the previous post, but I had no connection problems. This information, however, appear and I can not understand OpenCL if the programs are executed perfectly.
It happens regardless of the code that runs in kernel.
There 's something that interferes between the SDK: Intel and AMD.
My system has 4 GPU -----> 2xHD5970 + Intel (R) Core (TM) 2 Extreme CPU
[email protected]
Good evening to all. In my system using ATI Stream (ver.2.4) and intelsdk OpenCL.
Clinfo Running from the command prompt I get:
Vendor: Advanced Micro Devices, Inc.
Driver version: CAL 04/01/1353
Profile: FULL_PROFILE
Version: 1.1 OpenCL AMD-APP-SDK v2.4-pre-
tc1 (595.1)
Extensions: cl_amd_fp64 cl_khr_global_int32
_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomi
cs cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addres
sable_store cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_printf cl_amd
_media_ops cl_amd_popcnt cl_khr_d3d10_sharing
Device Type: CL_DEVICE_TYPE_GPU
Device ID: 4098
Max compute units: 20
Max dimensions work items: 3
Max work items [0]: 256
Max work items [1]: 256
Max work items [2]: 256
Max work group size: 256
Preferred vector char width: 16
Preferred short vector width: 8
Preferred vector int width: 4
Preferred long vector width: 2
Preferred vector float width: 4
Preferred vector double width: 0
Native char vector width: 16
Native vector short width: 8
Native vector int width: 4
Native long vector width: 2
Native vector float width: 4
Native vector double width: 0
Max clock frequency: 725Mhz
Address bits: 32
Max memory allocation: 268435456
Image support: Yes
Max number of images read arguments: 128
Max number of images write arguments: 8
Max 2D image width: 8192
Max 2D image height: 8192
3D Max image width: 2048
3D Max image height: 2048
Max 3D image depth: 2048
Within kernel samplers Max: 16
Max size of kernel argument: 1024
Alignment (bits) of base address: 32768
Minimum alignment (bytes) FOR ANY datatype: 128
Single precision floating point capability
Denorms: No
Quiet NaNs: Yes
Round to nearest even: Yes
Round to zero: Yes
Round to + ve and infinity: Yes
IEEE754-2008 fused multiply-add: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Global memory size: 1073741824
Constant buffer size: 65536
Max number of args constant: 8
Local memory type: Scratchpad
Local memory size: 32768
Preferred multiple kernel work group size: 64
Error correction support: 0
Unified memory for Host and Device: 0
Profiling timer resolution: 1
Device endianess: Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: No
Queue properties:
Out-of-Order: No
Profiling: Yes
Platform ID: 00000000015C1118
tc1 (595.1)
Device ID: 4098
Address bits: 32
Image support: Yes
Denorms: No
Quiet NaNs: Yes
Round to zero: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Available: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
tc1 (595.1)
Device Type: CL_DEVICE_TYPE_CPU
Device ID: 4098
Max compute units: 4
Max work items [0]: 1024
Max work items [1]: 1024
Max work items [2]: 1024
Max work size group: 1024
Max clock frequency: 3166Mhz
Address bits: 64
Max memory allocation: 2147483648
Image support: Yes
Max size of kernel argument: 4096
Alignment (bits) base address of: 1024
Denorms: Yes
Quiet NaNs: Yes
Round to zero: Yes
IEEE754-2008 fused multiply-add: No
Cache type: Read / Write
Cache line size: 64
Cache size: 32768
Global memory size: 8589017088
Local memory type: Global
Preferred multiple kernel work group size: 1
Unified memory for Host and Device: 1
Profiling timer resolution: 323
Available: Yes
Execute native function: Yes
Queue properties:
Out-of-Order: No
Profiling: Yes
Name: Intel Core 2 Extreme CPU
[email protected]
Vendor: GenuineIntel
Driver version: 2.0
tc1 (595.1)
cs cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_ex
tended_atomics cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_device_fis
sion cl_amd_device_attribute_query cl_amd_vec3 cl_amd_media_ops cl_amd_popcnt cl
_amd_printf cl_khr_d3d10_sharing
Platform Name: Intel OpenCL
Number of devices: 1
Device ID: 32902
Preferred vector double width: 2
Native vector double width: 2
Address bits: 4294967360
Max memory allocation: 2147254272
Image support: Yes
Max number of images write arguments: 128
Within kernel samplers Max: 128
Denorms: Yes
Quiet NaNs: Yes
Round to zero: No
Round to + ve and infinity: No
Cache line size: 64
Cache size: 6291456
Constant buffer size: 131072
Max number of args constant: 128
ERROR: clBuildProgram (-11)
zkleo
zkleo
Sure and 'bad ol set my OpenCL ICD. I apologize again, I ask help to you, this' my OpenCL icd:
cl_platform_id platforms * = Accelerated Parallel Processing AMD, Intel OpenCL;
vendor_name char [128] = {AMD (1002-2542), Intel (8086)};
cl_uint num_platforms = 2;
/ / get number of available platforms
cl_int clGetPlatformIDs err = (2, AMD Accelerated Parallel Processing, OpenCL Intel, AMD & {(1002-2542), Intel (8086)});
if (CL_SUCCESS! = err)
/ / handle error
platforms = (Parallel Processing Accelerated AMD, Intel OpenCL) malloc (
sizeof (cl_platform) {* AMD (1002-2542), Intel (8086)});
if (NULL == platforms)
/ / handle error
err = clGetPlatformIDs (5, GPU, CPU, Cypress, GenuineIntel);
/ / handle error
for (ui = 2 cl_uint; ui <5; + + ui)
err = clGetPlatformInfo (Advanced Micro Devices, Inc., GenuineIntel [ui]
AMD (1002-2542), Intel (8086),
128 * sizeof (char)
Intel (R) Core (TM) 2 Extreme CPU [email protected],
NULL);
/ / handle error
if (vendor_name! = Intel (R) Core (TM) 2 Extreme CPU [email protected])
if (strcmp (vendor_name, "Intel Corporation"))
return platforms [ui];
/ / handle error
I certainly misunderstood and poorly drawn OpenCL ICD.
ARNON_P_Intel
I've asked our engineering team to analyze your problem and we will return to you soon.
Thanks, Arnon
