OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Error build kernel on cpu device
MCHEI1
I used ioc32.exe -device = gpu to build a kernel, everything goes well, with build succeded, against when I use device = cpu no return, only an empty line.
And it generates an error report in the windows error log. see report.txt
My openCL platform is:
  | NAME = Intel (R) OpenCL
 CL_PLATFORM_PROFILE = FULL_PROFILE
 CL_PLATFORM_VERSION = OpenCL 2.1
 CL_PLATFORM_NAME = Intel (R) OpenCL
 CL_PLATFORM_VENDOR = Intel (R) Corporation
 CL_PLATFORM_EXTENSIONS = cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_fp64 cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
Devices:
 - 0 -
 CL_DEVICE_TYPE = 4
 CL_DEVICE_VENDOR_ID = 0x8086
 CL_DEVICE_NAME = Intel (R) HD Graphics 630
 CL_DEVICE_VENDOR = Intel (R) Corporation
 CL_DEVICE_VERSION = OpenCL 2.1 NEO
 CL_DRIVER_VERSION = 25.20.100.6472
 CL_DEVICE_PROFILE = FULL_PROFILE
 - 1 -
 CL_DEVICE_TYPE = 2
 CL_DEVICE_NAME = Intel (R) Core (TM) i5-7500 CPU @ 3.40GHz
 CL_DEVICE_VERSION = OpenCL 2.1 (Build 0)
 CL_DRIVER_VERSION = 7.6.0.0
--------- release of the event journal --------
Log Name: Application
Source: Application Error
Date: 06/03/2019 14:41:54
Event ID: 1000
Category of the task: (100)
Level: Error
Keywords: Classic
User: N / A
Computer: DESKTOP-U330PRO
Description:
Invalid application name ioc32.exe, version: 7.0.0.2567, timestamp: 0x5a327cca
Faulty module name: intelocl32.dll, version: 7.6.0.0, timestamp: 0x5b98450d
Exception code: 0xc0000005
Error offset: 0x0009ebd9
Process ID: 0x2910
Default application start time: 0x01d4d4225c89d69d
Faulting Application Path: path-to \ ioc32.exe
Faulty Module Path: C: \ Program Files (x86) \ Common Files \ Intel \ OpenCL \ bin \ x86 \ intelocl32.dll
Report ID: ed536526-b933-4e05-ada5-7802915479ec
Full name of the failed package:
