OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Failed to update machine list:Failed to initialize code builder API
Lu__Shan
Hi all Intel tutors
    I think I have already installed SDK 2017 and oracle-java-8 and libicu52.
But the error I encountered that error. It seems that my java is not correct. But I don't know where it is. I don't know where the log of code builder.
If you had also encountered that. Help me out please, Thanks a lot...
shan@shan-ZHAOYANG-E51-80:/etc/alternatives$ java -version
java version "1.8.0_191"
Java(TM) SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.191-b12, mixed mode)
shan@shan-ZHAOYANG-E51-80:/etc/alternatives$ javac -version
javac 1.8.0_191
shan@shan-ZHAOYANG-E51-80:/tmp/iss_env_shan_20181123130527$ cat eclipse.log
2018-11-23 13:06:01 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable)         - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/c.json: connect timed out
2018-11-23 13:10:22 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable)         - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/c.json: connect timed out
2018-11-23 13:10:23 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable)         - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/cpp.json: connect timed out
2018-11-23 13:10:24 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable)         - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/java.json: connect timed out
Sourcing /opt/intel/system_studio_2019/debugger_2019/bin/debuggervars.sh
Sourcing /opt/intel/system_studio_2019/env.d/linux/70-gdb-env.sh
Sourcing /opt/intel/system_studio_2019/env.d/linux/70-iot_ide.sh
ERROR - Please install docker and ensure it is in the environment PATH
Sourcing /opt/intel/system_studio_2019/env.d/linux/70-openipc-env.sh
Sourcing /opt/intel/system_studio_2019/env.d/linux/70-tca-env.sh
Sourcing /opt/intel/system_studio_2019/env.d/linux/70-trace-env.sh
Sourcing /opt/intel/system_studio_2019/env.d/linux/70-wrl-env.sh
Environment variables
LC_PAPER=zh_CN.UTF-8
XDG_VTNR=7
MANPATH=/opt/intel/system_studio_2019/documentation_2019/en/debugger/gdb-ia/man/:/usr/local/man:/usr/local/share/man:/usr/share/man:/usr/lib/jvm/java-8-oracle/man
LC_ADDRESS=zh_CN.UTF-8
XDG_SESSION_ID=c4
CLUTTER_IM_MODULE=xim
XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/shan
LC_MONETARY=zh_CN.UTF-8
GIO_LAUNCHED_DESKTOP_FILE_PID=8765
SESSION=ubuntu
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
INTEL_LICENSE_FILE=/opt/intel/system_studio_2019/licenses:/opt/intel/licenses:/home/shan/intel/licenses:/Users/Shared/Library/Application Support/Intel/Licenses
GPG_AGENT_INFO=/home/shan/.gnupg/S.gpg-agent:0:1
ECLIPSE_DBG_SETTINGS_FILE=/opt/intel/system_studio_2019/settings.properties
XDG_MENU_PREFIX=gnome-
SHELL=/bin/bash
NPK_ROOT=/opt/intel/system_studio_2019/system_debugger_2019/system_trace
DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
DOCKER_HOST=unix:///var/run/docker.sock
INSTALL_DIR=/opt/intel/system_studio_2019
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
LC_NUMERIC=zh_CN.UTF-8
LIBVA_DRIVER_NAME=iHD
UPSTART_SESSION=unix:abstract=/com/ubuntu/upstart-session/1000/7957
GNOME_KEYRING_CONTROL=
GTK_MODULES=gail:atk-bridge:
WIND_LINUX_CONFIGURE=/opt/intel/system_studio_2019/WindRiver/wrlinux-x/scripts/project-configure.sh
NO_PROXY=127.0.0.1
USER=shan
LD_LIBRARY_PATH=/opt/intel/system_studio_2019/debugger_2019/libipt/intel64/lib
QT_ACCESSIBILITY=1
LC_TELEPHONE=zh_CN.UTF-8
INTELOPENCLSDK=/opt/intel/opencl/SDK
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session1
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
ISS_OPENIPCBINDIR=/opt/intel/system_studio_2019/system_debugger_2019/debugger/openipc/Bin
SESSION_MANAGER=local/shan-ZHAOYANG-E51-80:@/tmp/.ICE-unix/8363,unix/shan-ZHAOYANG-E51-80:/tmp/.ICE-unix/8363
DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path
ISS_ROOT=/opt/intel/system_studio_2019
GIO_LAUNCHED_DESKTOP_FILE=/home/shan/Desktop/Intel(R) System Studio.desktop
XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg
NLSPATH=/opt/intel/system_studio_2019/debugger_2019/gdb/intel64/share/locale/%l_%t/%N
PATH=/opt/intel/system_studio_2019/system_debugger_2019/system_trace/bin:/opt/intel/system_studio_2019/debugger_2019/gdb/intel64/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin
DESKTOP_SESSION=ubuntu
ISS_TOOLS_ROOT=/opt/intel/system_studio_2019/tools
TEMPDIR=/tmp/iss_env_shan_20181123130527
QT_IM_MODULE=fcitx
QT_QPA_PLATFORMTHEME=appmenu-qt5
WIND_HOME=/opt/intel/system_studio_2019/WindRiver
TCA_INSTALL_DIR=/opt/intel/system_studio_2019/system_debugger_2019/tca
LC_IDENTIFICATION=zh_CN.UTF-8
JOB=dbus
PWD=/opt/intel/system_studio_2019
XDG_SESSION_TYPE=x11
JAVA_HOME=/usr/lib/jvm/java-8-oracle
XMODIFIERS=@im=fcitx
LANG=en_US.UTF-8
GNOME_KEYRING_PID=
GDM_LANG=en_US
MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path
LC_MEASUREMENT=zh_CN.UTF-8
MFX_HOME=/opt/intel/mediasdk
IM_CONFIG_PHASE=1
COMPIZ_CONFIG_PROFILE=ubuntu
PAPERSIZE=a4
ITH_PYTHON_DIR=
ISS_TCA=1
GDMSESSION=ubuntu
INTEL_PYTHONHOME=/opt/intel/system_studio_2019/debugger_2019/python/intel64/
LOGFILE=/tmp/iss_env_shan_20181123130527/iss_env.log
GTK2_MODULES=overlay-scrollbar
SESSIONTYPE=gnome-session
HOME=/home/shan
SHLVL=1
XDG_SEAT=seat0
LANGUAGE=en_US:en
ISS_ENV_DIR=/opt/intel/system_studio_2019/env.d/linux
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
XDG_SESSION_DESKTOP=ubuntu
LOGNAME=shan
XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop:/var/lib/snapd/desktop
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-KW5PwbdzWR
QT4_IM_MODULE=fcitx
J2SDKDIR=/usr/lib/jvm/java-8-oracle
INFOPATH=/opt/intel/system_studio_2019/documentation_2019/en/debugger/gdb-ia/info/
INSTANCE=
DISPLAY=:0
XDG_RUNTIME_DIR=/run/user/1000
XDG_CURRENT_DESKTOP=Unity
GTK_IM_MODULE=fcitx
J2REDIR=/usr/lib/jvm/java-8-oracle/jre
LC_TIME=zh_CN.UTF-8
LC_NAME=zh_CN.UTF-8
XAUTHORITY=/home/shan/.Xauthority
_=/usr/bin/env
