OpenCL* for CPU
1735 Discussions
How global and local work sizes are distributed in this function?
Naing__Nyan
This is from a sample program for OpenCL programming. I am confused about how global and local work size are computed. They are computed based on the image size.
Image size is 1920 x 1080 (w x h).
What I assumed is global_work_size[0] and global_work_size[1] are grids on image.
But now global_work_size is {128, 1088}.
Then local_work_size[0] and local_work_size[1] are grids on global_work_size. local_work_size is {128, 32}.
But total groups, num_groups = 34, but it is not 128 x 1088.
Max workgroup_size available at device is 4096.
How is the image distributed into such global and local work group sizes?
They are calculated in the following function.
    clGetKernelWorkGroupInfo(histogram_rgba_unorm8, device, CL_KERNEL_WORK_GROUP_SIZE, sizeof(size_t), &workgroup_size, NULL);
        size_t  gsize[2];
        int     w;
        if (workgroup_size <= 256)
            gsize[0] = 16;//workgroup_size is formed into row & col
            gsize[1] = workgroup_size / 16;
        else if (workgroup_size <= 1024)
            gsize[0] = workgroup_size / 16;
            gsize[1] = 16;
        else
            gsize[0] = workgroup_size / 32;
            gsize[1] = 32;
        local_work_size[0] = gsize[0];
        local_work_size[1] = gsize[1];
        w = (image_width + num_pixels_per_work_item - 1) / num_pixels_per_work_item;//to include all pixels, num_pixels_per_work_item is added first
        global_work_size[0] = ((w + gsize[0] - 1) / gsize[0]);//col
        global_work_size[1] = ((image_height + gsize[1] - 1) / gsize[1]);//row
        num_groups = global_work_size[0] * global_work_size[1];
        global_work_size[0] *= gsize[0];
        global_work_size[1] *= gsize[1];
    err = clEnqueueNDRangeKernel(queue, histogram_rgba_unorm8, 2, NULL, global_work_size, local_work_size, 0, NULL, NULL);
    if (err)
        printf("clEnqueueNDRangeKernel() failed for histogram_rgba_unorm8 kernel. (%d)\n", err);
        return EXIT_FAILURE;
