OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1739 Discussions
Install opencl_runtime_16.1_x64_rh_5.2.0.10002
jupiter_h_
I've tried to run install.sh, it did not give me the choices to select installation path. How can I set the installation path?
Thank you.
Vladimir_L_Intel
you can use "Customize installation" option in installer.
In command line installer it is option 2 on step 4.
jupiter_h_
Thank you very much, that did the trick.
