System Details
Ubuntu 22.04
Small Form PC with Intel N95
Software from apt.repos.intel.com/oneapi
intel-oneapi-runtime-opencl
intel-oneapti-runtime-compilers
intel-opencl-icd
etc..
clinfo shows the following
OpenCL 3.0
2023.15.3.0.20_160000
I've tried to set all the options with CL_CONFIG_CPU_TARGET_ARCH within a terminal before running after receiving the error I put in the subject line. No matter which target I select, it ends in the same error. Is it possible it's just something with the Intel N95 CPU? Hoping there's a fix.
- « Previous
- 1
- 2
- Next »
Sorry for the delay reply. We are evaluating this issue internally and will let you know when we have any conclusions.
Sorry for the delay reply. We tested some other OpenCL applications on this machine and all of them could run successfully. There maybe one issue for this application, we will try to fix it.
I will let you know when there are any updates.
Any help in altering fosphor to run would be greatly appreciated or at the least any help crafting up a ticket to put on the fopshor GitHub in the hope someone else can fix it would also be great.
This issue will be fixed in the next release. Please test your code again when it is available.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
- « Previous
- 1
- 2
- Next »
