OpenCL* for CPU
1739 Discussions
Intel OpenCL CPU only runtime version 7.* and maximum kernel length crash
Achille_P_
we noticed that the new Intel OpenCL CPU only runtime series 7.* crashes in its OclCpuBackEnd64.dll during the clBuildProgram() method when a rather long source code is passed. The very same piece of code is working properly under the previous versions of the Intel OpenCL CPU only runtime (version 6.* and earlier), as well as under the NVidia, AMD, and Intel GPU runtime.
By cutting a few dozen lines of code, the clBuildProgram() works.
We are facing this problem under all the 7.* CPU only versions we can test in our firm:
- 7.0.* (the one available as Experimental through the Intel OpenCL SDK)
- 7.2.* (as the CPU only runtime available with the HD Graphics driver)
- 7.5.* (as the CPU only runtime availabe with another Intel GPU)
Jeffrey_M_Intel1
Thanks for this report.  The team will be glad to investigate this bug, but to do so we will need kernel source showing this problem as a reproducer.  If there are any concerns with posting to a public forum you can use the "send author a message" link by my name to send a private message.
Achille_P_
Hi Jeffrey,
thanks for your answer. I've no problem in privately sending you the code snippet, but I can't find the "send message" option you mentioned. I can drop you an email if you provide me your address.
Jeffrey_M_Intel1
If you are logged in to the forum, you can find "send author a message" above this post.
Alternately, if this does not work for any reason, my email is jeffrey.mcallister@intel.com.
Achille_P_
Nada, I only have "quote" and the post number. Maybe Chrome is not friendly enough. Will send you an email right now, thanks.
Jeffrey_M_Intel1
Thanks for sending your reproducer. The bug is filed.
