OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1734 Discussions
Is driver version meant to be locale-sensitive
Bruce_M_
Hi
I develop a library that does autotuning of kernels in advance. I've discovered that the value of CL_DRIVER_VERSION is dependent on the current locale, which is problematic because I use the driver version as part of the key when looking up tuning parameters, and so an application running under a different locale will think that it is using a different driver version and needs re-tuning. For example, the CL_DRIVER_VERSION is 1.2.0.76921 in the C locale, but 1.2.0.76,921 in the en_GB.UTF-8 locale. This is on Linux.
Bruce
Yuri_K_Intel
Hi, I couldn't reproduce it so far. I tried 'export LANG=en_GB.UTF-8'. Could you please provide additional details - OS version, necessary environment variables? Thanks, Yuri
Bruce_M_
I've attached a program that demonstrates the issue. I'm running it on Ubuntu 13.10 64-bit. The output of "locale" when I run it is
[plain]LANG=en_GB.UTF-8
LANGUAGE=en_GB:en
LC_CTYPE="en_GB.UTF-8"
LC_NUMERIC=en_GB.UTF-8
LC_TIME=en_GB.UTF-8
LC_COLLATE=C
LC_MONETARY=en_ZA.UTF-8
LC_MESSAGES="en_GB.UTF-8"
LC_PAPER=en_ZA.UTF-8
LC_NAME=en_ZA.UTF-8
LC_ADDRESS=en_ZA.UTF-8
LC_TELEPHONE=en_ZA.UTF-8
LC_MEASUREMENT=en_GB.UTF-8
LC_IDENTIFICATION=en_ZA.UTF-8
LC_ALL=[/plain]
The output when I run it is
[plain]Device name:         Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Driver version: 1.2.0.76,921[/plain]
If I comment out the first line of main() (so that the program is not locale-aware), it outputs:
Driver version: 1.2.0.76921[/plain]
i.e. no comma.
Yuri_K_Intel
Yes, now it's reproduced. I will submit a ticket for it Thanks, Yuri
Yariv_A_Intel1
This issue will be fixed in our next release.
Thanks, Yariv
