OpenCL* for CPU
Miscompiled control flow
Kloeckner__Andreas
Hi there,
I've attached a test case (a gutted version of a segmented scan) that gets miscompiled by intel_sdk_for_ocl_applications_2013_xe_runtime_3.0.67279_x64, at least when running on my i7-2620M.
Specifically, when running this self-contained test code using PyOpenCL, I get the line
gid:0 fsii:0
printed 16 times for each of the two work groups. If you look at the kernel, that means that the printf() in the trailing snippet:
    if (get_local_id(0) == 0)
      printf("gid:%d fsii:%d\n", psc_GID_0, psc_first_segment_start_in_interval);
got executed 16 times for group id 0. In my book, it should be executed exactly once. (Confirmed by running against other implementations. Intel OpenCL 2012 also gets this right.)
Andreas
Raghupathi_M_Intel
Sorry for late response. Thanks for the code. We'll take a look and get back to you.
Yuri_K_Intel
Hi Andreas, I was able to reproduce the issue on the release version (67279), but I don't see it on our latest development versions, the output I get is: gid:0 fsii:0 gid:1 fsii:0 So obviously it has been fixed since that. Thanks, Yuri
Kloeckner__Andreas
Sounds good, thanks for the heads-up. How soon do you think your dev version will turn into a release?
Thanks, Andreas
JLuna5
Hi, the control flow you have established on the estructure
