OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Samples for Linux and less hard coded paths
andreyi
Hi!
Just to continue the thread Intel OpenCL Samples and Offline Compiler for Linux?
There is a new release, but at least two known issues are not yet closed: samples for Linux and hard coded paths. The last I mentioned here.
In /usr/lib64/libOpenCL.so there is a hard coded path /etc/opencl/vendors/...icd. It'd be practically to check the environment variable OPENCL_VENDOR_PATH before trying the default path.
Andrey
Nisha_A_
Hi..
Thanks for your post. I am really seeking for your help . I am using Intel OpenCL sdk , I wants to change the default icd file PATH which is hardcoded in libOpenCL.so. Could you please help me for editing of libOpenCL.so (hex) code to change the /etc/OpenCL/vendors path?
Yuri_K_Intel
andreyi wrote:
Hi!
Andrey
Hi Andrey,
You can find Intel openCL samples for Linux here - http://software.intel.com/en-us/articles/intel-sdk-for-opencl-applications-xe-samples-getting-started
Yuri
JLuna5
Hi, your path is same that your app code?
