OpenCL* for CPU
Samples for Linux and less hard coded paths
andreyi
Hi!
Just to continue the thread Intel OpenCL Samples and Offline Compiler for Linux?
There is a new release, but at least two known issues are not yet closed: samples for Linux and hard coded paths. The last I mentioned here.
In /usr/lib64/libOpenCL.so there is a hard coded path /etc/opencl/vendors/...icd. It'd be practically to check the environment variable OPENCL_VENDOR_PATH before trying the default path.
Andrey
Nisha_A_
Hi..
Thanks for your post. I am really seeking for your help . I am using Intel OpenCL sdk , I wants to change the default icd file PATH which is hardcoded in libOpenCL.so. Could you please help me for editing of libOpenCL.so (hex) code to change the /etc/OpenCL/vendors path?
Yuri_K_Intel
andreyi wrote:
Hi!
Andrey
Hi Andrey,
You can find Intel openCL samples for Linux here - http://software.intel.com/en-us/articles/intel-sdk-for-opencl-applications-xe-samples-getting-started
Yuri
JLuna5
Hi, your path is same that your app code?
