OpenCL* for CPU
1733 Discussions
[NOT SOLVED] ioc64: simple kernel killed
mike_p_4
A kernel which works perfectly well under Mali GPU, does not compile under Intel GPU.
ioc64 -cmd=build -input=TestKernel.cl -device=gpu -ir=TestKernel.bin hangs and then operation is killed.
If I specify -device=cpu, it works.
I also tried to load the kernel as source, instead as binary, but it hangs as well.
If I take out the return from C6, or some other particular lines of code, it compiles.It's driving me mad.
Jeffrey_M_Intel1
Thanks for this report.  The kernel compiles for GPU with Windows ioc64 but not Linux.  This seems to be a bug.  I've filed it for the dev team.
mike_p_4
Hi Jeffrey,
Thanks. The problem is not ioc64 but most probably the Intel gpu, that is because I tried to load the kernel without compile it to binary, so WithSource instead of WithBinary. I also tried gcc, icc, Intel sdk and amd sdk and the issue remains. The most strange thing is that, by commenting out some lines, it works.
Jeffrey_M_Intel1
The behavior reported with ioc64 is not as expected, so we will continue to work on improving it.  Glad you have a workaround.
mike_p_4
Hi Jeffrey,
Thanks for that, I do not have a workaround, I'm just saying that if I comment random lines, it compiles, but then the kernel is useless.
I'm waiting until Intel fix the issue, please fix it as soon as possible, as I am stuck. It must be the i915 driver.
