OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
OpenCL CPU runtime cannot find any platforms
AfshinArefi
I am trying to test Intel's CPU runtime for OpenCL but my test program fails to get any platforms on the system and "clGetPlatformIDs" returns "CL_PLATFORM_NOT_FOUND_KHR".
To prepare the system I have followed the instructions to install the runtime through oneapi instructions, so I have installed:
sudo yum install intel-oneapi-runtime-opencl
sudo yum install intel-oneapi-runtime-compilers.x86_64
sudo yum install opencl-headers.noarch
 My Cpu is
Intel(R) Xeon(R) CPU E5-2683 v4 @ 2.10GHz
which seems to have the requirements for the X86 CPU runtime.
The code I am test with is just a simple
#include<CL/cl.h>
#include<iostream>
using namespace std;
int main() {
    unsigned int num;
    cout << clGetPlatformIDs(0, NULL, &num) << endl;
    cout << num << endl;
    return 0;
Building with
g++ test.cpp -o test -lOpenCL
And the call returns error "-1001" which is "CL_PLATFORM_NOT_FOUND_KHR"
Using strace I can see that these related files are being loaded:
/opt/intel/oneapi/lib/libOpenCL.so.1
/etc/OpenCL/vendors/intel64.icd
/opt/intel/oneapi/lib/intel64/libintelocl.so
Am i missing a step? Something else I need to install?
P.S.: Installing the complete base toolkit
sudo yum install intel-basekit
Did not change anything.
Labels (2)
AfshinArefi
Manually installing the older package for the runtime
l_opencl_p_18.1.0.015.tgz
Works well and as expected.
Any idea what is the problem with the new packages based on the oneAPI?
cw_intel
Can you tell me the version of your OS?  You can refer to the system requirements and check if your OS meets the requirements.  https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html
AfshinArefi
Thank you for your response. My OS is "CentOS Linux release 7.9.2009 (Core)" which is in the supported OSes I think.
Ben_A_Intel
Hi, did you source the setvars.sh configuration file to setup your oneAPI installation?
On my Ubuntu system this is done via:
$ source /opt/intel/oneapi/setvars.sh
For more information please see:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/oneapi-development-environment-setup/use-the-setvars-script-with-linux-or-macos/use-a-config-file-for-setvars-sh-on-linux-or-macos.html
I've found this is required to setup some library paths for the CPU OpenCL implementation.
cw_intel
I'm sorry to tell you that the OpenCL CPU Runtime in oneAPI Base Toolkit doesn't support  Centos 7.  OpenCL CPU Runtime is shipped with Intel® oneAPI DPC++/C++ Compiler, and for the system requirements of the compiler, please refer to  https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html
