OpenCL* for CPU
OpenCL HD Graphics 4000 compiler crash during compilation
Ian_J_1
Apologies in advance if this has been reported before:
The OpenCL HD Graphics 4000 compiler crashes when I attempt to build the following minimal kernel
__kernel void pix(__write_only image2d_t im, const ulong data)
    int2 coord = { 1, 2 };
    if (data)
        write_imagef(im, coord, (float4)(0.0f,1.0f,0.0f,1.0f));
    else
        write_imagef(im, coord, (float4)(0.0f,0.0f,0.0f,1.0f));
The set-up is as follows:
Windows 8 (64 bit), Intel graphics driver version 15.28.12.2932(9.17.10.2932), Intel SDK for OpenCLApplications 2013 Beta.
The compiler crash occurs in both my application and when I try to compile using the offline compiler. The kernel builds and executes successfully for the CPU. Is this a known issue?
Rami_J_Intel
Hi Ian;
Can you please try query for the CL_PROGRAM_BUILD_LOG using clGetProgramBuildInfo API and see what message it returns for the failiing case?
Ian_J_1
Rami,
Thanks for replying. The compiler actually crashes during the compilation step, so it is not possible to make the clGetProgramBuildInfo API call. When I try to build the kernel using the offline kernel builder it compiles correctly when I select Intel CPU as the target, but the compiler crashes when I select Intel HD Graphics as the target. When the compiler crashes I get the following information from Windows:
Problem Event Name:    APPCRASH
Application Name:    ioc64.exe
Application Version:    3.0.0.43087
Application Timestamp:    5018e60a
Fault Module Name:    igdfcl64.dll
Fault Module Version:    8.1.0.2932
Fault Module Timestamp:    50c924e2
Exception Code:    c0000005
Exception Offset:    000000000083a94a
OS Version:    6.2.9200.2.0.0.768.101
Locale ID:    2057
If I comment out the the "else" then the compilation succeeds (but obviously the logic of the kernel changes).
Would it be possible for you to cut and paste the kernel I've given in the opening post and try to compile in the offline Kernel Builder, to see if you can reproduce the crash?
Ian
Raghupathi_M_Intel
I tried your kernel and indeed the compiler crashes during clBuildProgram() call, so querrying the build log is not possible. I will try a later driver to see if the issue is fixed. I'll keep you posted.
Raghu
Chuck_De_Sylva
We tested this against an internal driver slated for a future release and the issue is resolved. We don't have a date for you as to when it will be released, but it should be out shortly.
Ian_J_1
Thanks for investigating. I'll look forward to the new driver.
LLess
I have seen crashes in the compiler too and while I don't have the issue right now it would be good if the compiler was able to catch the exception itself and avoid crashing so we can try to get some error somehow.
Laurent.
Ian_J_1
I can confirm that the issue is resolved with the release SDK for OpenCL Applications 2013 and driver 15.31.3.3071 (9.18.10.3071).
Ian
