OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1735 Discussions
OpenCL Kernel Builder : Missing support for image3d_t
LLess
I would really like to use the Analyze part of the Kernel builder but since most of my kernels are taking an image3d_t as input it doesn't work.
I am not sure if it has reported it before or not, but can you please add the image3d_t format to supported list of inputs.
Loading from file as Raw data would be enough.
Also I have defined a struct buffer that I am passing as constant, it is not really clear in that case how to define it in the Kernel Builder.
An example in the documentation would be welcome.
Laurent
Raghupathi_M_Intel
Laurent,
We will consider your suggestions for the future release. Thanks for the feedback.
Raghu
Oren_S_Intel1
Hi Laurent,
Indeed both structs and image3d are not supported today. image1d aren't as well, and we consider supporting all 3 in the future if there is a need for them.
That said, if you could somehow split your structs to primitives in the kernel arguments - that will allow you to do the analysis with today's Kernel Builder.
Oren
LLess
Hi Oren,
Indeed the new OpenCL 1.2 image formats are not supported. I hadn't checked them since I was using OpenCL 1.1 until recently.
Actually I removed the struct I had for some of the kernels and these were using the image2d so I can analyze the kernels now.
However this doesn't really help me to understand why they are not working on HD4000 (they work fine on I7, slow but fine).
Raghu has the code for that and the test application.
Laurent.
