OpenCL* for CPU
OpenCL extension cl_intel_simultaneous_sharing
allanmac1
Is there any documentation on this extension in the new 3960 driver?
  • Added support for OpenCL extension cl_intel_simultaneous_sharing to allow sharing of memory buffers between OpenCL, OpenGL, and DirectX.  This feature is used by Adobe* applications such Photoshop CC*
Robert_I_Intel
Here is documentation:
Name String
Extension Type
    OpenCL platform extension
Dependencies
    OpenCL 1.2. This extension is written against revision 19 of the
    OpenCL 1.2 Specification and revision 19 of the OpenCL 1.2 Extension
    Specification.
Overview
    Currently OpenCL 1.2 Extension Spec forbids to specify interoperability
    with multiple graphics APIs at clCreateContext or clCreateContextFromType
    time and defines that CL_INVALID_OPERATION should be returned in such
    cases as noted e.g. in chapters dedicated to sharing memory objects with
    Direct3D 10 and Direct3D 11.
    The goal of this extension is to relax the restrictions and allow to
    specify simultaneously these combinations of interoperabilities that are
    supported by a given OpenCL device.
New Tokens
    Accepted as a property being queried in the <param_name> parameter
    of clGetDeviceInfo:
        CL_DEVICE_SIMULTANEOUS_INTEROPS_INTEL        0x4104
        CL_DEVICE_NUM_SIMULTANEOUS_INTEROPS_INTEL    0x4105
Additions to chapter 4 of the OpenCL 1.2 Specification
    4.2 Querying Devices
    Extend table 4.3 to include the following entry:
    cl_device_info             Return Type  Description
    CL_DEVICE_NUM_SIMULTANEOUS cl_uint      Number of supported combinations
    _INTEROPS_INTEL                         of graphics API interoperabilities
                                            that can be enabled simultaneously
                                            within the same context.
                                            The minimum value is 1.
    CL_DEVICE_SIMULTANEOUS     cl_uint[]    List of <n> combinations of context
    _INTEROPS_INTEL                         property names describing graphic APIs
                                            that the device can interoperate with
                                            simultaneously by specifying the
                                            combination in the <properties>
                                            parameter of clCreateContext and
                                            clCreateContextFromType.
                                            Each combination is a set of 2
                                            or more property names and is
                                            terminated with zero.
                                            <n> is the value returned by the
                                            query for
                                            CL_DEVICE_NUM_SIMULTANEOUS_INTEROPS_INTEL.
    4.4 Contexts
    Add to the list of errors for clCreateContext:
    “CL_INVALID_OPERATION if a combination of interoperabilities with multiple graphics
    APIs is specified which is not on the list of valid combinations returned by
    the query for CL_DEVICE_SIMULTANEOUS_INTEROPS_INTEL.”
    Add to the list of errors for clCreateContextFromType the same new errors
    described above for clCreateContext.
Additions to section 9.6.4 of the OpenCL 1.2 Extension Specification
    Replace the section about CL_CONTEXT_INTEROP_USER_SYNC property support with:
    “OpenCL / OpenGL sharing does not support the CL_CONTEXT_INTEROP_USER_SYNC property
    defined in table 4.5. Specifying this property when creating a context with OpenCL /
    OpenGL sharing will return an appropriate error or be ignored for OpenGL sharing if
    sharing with another graphics API supporting the CL_CONTEXT_INTEROP_USER_SYNC
    property is also specified.”
    Replace the description of CL_INVALID_PROPERTY error code with:
    “errcode_ret returns CL_INVALID_PROPERTY if an attribute name other than those
    specified in table 4.5 or if CL_CONTEXT_INTEROP_USER_SYNC is specified in properties
    and there is no graphics API interoperability specified that supports it.”
Additions to section 9.9.5 of the OpenCL 1.2 Extension Specification
    Remove the following description of CL_INVALID_PROPERTY error code:
    “CL_INVALID_OPERATION if Direct3D 10 interoperability is specified by setting
    CL_INVALID_D3D10_DEVICE_KHR to a non-NULL value, and interoperability with another
    graphics API is also specified.”
Additions to section 9.11.5 of the OpenCL 1.2 Extension Specification
    “CL_INVALID_OPERATION if Direct3D 11 interoperability is specified by setting
    CL_INVALID_D3D11_DEVICE_KHR to a non-NULL value, and interoperability with another
Additions to cl_intel_dx9_media_sharing extension specification:
    “CL_INVALID_OPERATION if DirectX 9 interoperability is specified by setting
    CL_CONTEXT_D3D9_DEVICE_INTEL, CL_CONTEXT_D3D9EX_DEVICE_INTEL, or
    CL_CONTEXT_DXVA_DEVICE_INTEL to a non-NULL value, and interoperability with any
    other graphics API is also specified.”
Example Usage
   cl_uint  SimInteropsNum;
    cl_uint* SimInterops;
    size_t   SimInteropsSize;
    clGetDeviceInfo( deviceID,
                     CL_DEVICE_NUM_SIMULTANEOUS_INTEROPS_INTEL,
                     sizeof( SimInteropsNum ),
                     &SimInteropsNum,
                     NULL );
                     CL_DEVICE_SIMULTANEOUS_INTEROPS_INTEL,
                     0,
                     NULL,
                     &SimInteropsSize );
    SimInterops = new cl_uint[ SimInteropsSize / sizeof( cl_uint ) ];
                     SimInteropsSize,
                     SimInterops,
                     NULL );
    bool SimInteropsCheck[] = { false, false, false };
    bool GLD3D11SimInteropSupported = false;
    cl_uint property = 0;
    for( int i = 0; i < SimInteropsNum; i++ )
        SimInteropsCheck[0] = false;
        SimInteropsCheck[1] = false;
        SimInteropsCheck[2] = false;
        do
            property = *SimInterops++;
            if( property == CL_GL_CONTEXT_KHR )
                SimInteropsCheck[0] = true;
            if( property == CL_WGL_HDC_KHR )
                SimInteropsCheck[1] = true;
            if( property == CL_CONTEXT_D3D11_DEVICE_KHR )
                SimInteropsCheck[2] = true;
        while( property != 0 );
        if( SimInteropsCheck[0] && SimInteropsCheck[1] && SimInteropsCheck[2] ){
            GLD3D11SimInteropSupported = true;
            printf("This device supports GL and D3D11 simultaneous sharing.\n");
            break;
    if( !GLD3D11SimInteropSupported ){
        printf("This device doesn't support GL and D3D11 simultaneous sharing.\n");
