OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1739 Discussions
Passing #defines in as build options
ABoxe
I would like to pass some compile time constants in as build options:
eg:  "-D BUFFER_SIZE=512"
and then I would like to declare the following variable in my kernel:
local buffer[BUFFER_SIZE];
When I try this, (visual studio 2012) I get errors. Is there a way of doing this with the intel SDK and
visual studio integration?
Thanks!
Yuri_K_Intel
Hi Aaron, Could you please rephrase your question? What exactly are you trying to do and what errors do you get? My understanding is that you should just pass "-D BUFFER_SIZE=512" as a compiler option to clBuildProgram (or clCompileProgram) and this macro will be defined in your kernel so you can use it. And I don't see any relation to Visual Studio. Thanks, Yuri
ABoxe
THanks, Yuri. Visual Studio does static checking on opencl file
when compiling C/C++ code. And it doesn't know about the compiler option passed to clBuildProgram.
So it flags
as an error.
I would like the visual studio plugin to somehow know about the clBuildProgram complier options.
Is this clearer?
THanks,
Aaron
Yuri_K_Intel
Yes, thanks. You should be able to set the necessary build options in 'Project properies'->'Intel SDK for OpenCL Applications'->'General'->'additional build options': -D BUFFER_SIZE=512 Please, let me know if that works for you. Thanks, Yuri
ABoxe
Thanks, Yuri. Unfortunately, that will not work.
I would like to build different programs using the same kernel code, but with different configurations of #defines.
For example:
Program 1:  kernel1  with  BUFFER_SIZE=512
Program2: kernel1 with BUFFER_SIZE=1028
Also, when I tried your suggestion, I got CL_INVALID_KERNEL errors.  So, it doesn't actually work :(
Thanks again,
Aaron
ABoxe
Any ideas on how to resolve this?  Any workarounds?
Aaron
Jeffrey_M_Intel1
You could consider your kernel source as a string and build it from values defined in the host program.
That is,
char *kernelSource2 ="
local buffer[%d]; \n
sprintf(kernelSource,kernelSource2,BUFFER_SIZE);
program = clCreateProgramWithSource(context, 1,
                            (const char **) & kernelSource, NULL, &err);
Will this work for what you are trying to do?
ABoxe
Ok, ok, my bad here. Yuri's suggestion does work.
1) Right click on .cl file and add a command line parameter D BUFFER_SIZE=512
2) pass the same parameter in when calling clBuildProgram
Now, the compiler is happy, and the visual studio plugin is happy.
