OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1732 Discussions
Problems with Intel HD Graphics 4000 video card
Vanessa_O_
I created an OpenCL program to execute some mathematic operations. It worked fine in Nvidia and AMD video cards (result matched with wolframalpha, for instance) but when I tried to use a notebook with an Intel HD Graphics 4000 video card, that supports openCL, my program returned unexpected results for some functions.
Those functions were erf, erfc, tgamma and lgamma. I thought my video card had a problem, but I tried in another 3 machines with Intel HD Graphics 4000 and obtained the same results from the first one.
Some examples:
erf( 0.25 ) = 0.0262698
erfc( 0.25 ) = 0.97373
lgamma( 5.5 ) = 1.70475
Another video cards:
erf( 0.25 ) = 0.276326
erfc( 0.25 ) = 0.723674
lgamma( 5.5 ) = 3.95781
I tried it configurations
OpenCL version: 1.1
OpenCL driver version: 8.15.10.2778
and
OpenCL version: 1.1
OpenCL driver version: 9.17.10.2932
Does anyone know the reason behind the different results?
Raghupathi_M_Intel
Do you have a reproducer? I can probably try to create one but it'll be easier and faster if you already have a reproducer.
Raghu
Vanessa_O_
Here is a simple program with a kernel that calculates the values on the functions I mentioned before, just for testing purposes. It will get only the first device, so the computer must have only the intel hd 4000 to notice the issue with this program.
[cpp]
#include <iostream>
#include <fstream>
#include <string.h>
using namespace std;
#include <CL/cl.h>
#define DATA_SIZE (1*1*1)
const char *KernelSource = " \\n" \
"__kernel void math( \\n" \
" const float input0, \\n" \
" const float input1, \\n" \
" __global float* output0, \\n" \
" __global float* output1, \\n" \
" __global float* output2, \\n" \
" __global float* output3, \\n" \
" const unsigned int count) \\n" \
"{ \\n" \
" int i = get_global_id(0); \\n" \
" if(i < count){ \\n" \
" output0 = erf(input0); \\n" \
" output1 = erfc(input0); \\n" \
" output2 = tgamma(input1); \\n" \
" output3 = lgamma(input1); \\n" \
"}} \\n" \
"\\n";
int main(int argc, char* argv[])
int devType = CL_DEVICE_TYPE_GPU;
cl_int err; // error code returned from api calls
size_t global; // global domain size for our calculation
size_t local;
cl_platform_id cpPlatform; // OpenCL platform
cl_device_id device_id; // compute device id
cl_context context; // compute context
cl_command_queue commands; // compute command queue
cl_program program; // compute program
cl_kernel kernel; // compute kernel
err = clGetPlatformIDs(1, &cpPlatform, NULL);
err = clGetDeviceIDs(cpPlatform, devType, 1, &device_id, NULL);
context = clCreateContext(0, 1, &device_id, NULL, NULL, &err);
commands = clCreateCommandQueue(context, device_id, 0, &err);
program = clCreateProgramWithSource(context, 1,
(const char **) &KernelSource,
NULL, &err);
err = clBuildProgram(program, 1, &device_id, NULL, NULL, NULL);
kernel = clCreateKernel(program, "math", &err);
cl_float defined_data0[5] = {0.000000000000f, 0.250000000000f, 0.750000000000f, 1.200000000000f, 2.100000000000f};
cl_float defined_data1[5] = {5.500000000000f, 7.400000000000f, 1.230000000000f, 2.780000000000f, 6.890000000000f};
cl_float expected_data0[5] = { 0.0000000000000000000000000f,
0.2763263901682369295107790f,
0.7111556336535151327631066f,
0.9103139782296353688714058f,
0.9970205333436670158317981f,};
cl_float expected_data1[5] = { 1.0000000000000000000000000f,
0.7236736098317630704892210f,
0.2888443663464848672368934f,
0.0896860090223934799878963f,
0.0029794679643595611119777f,
cl_float expected_data2[5] = { 52.3427777845535207174032521f,
1541.3364759429129485779341735f,
0.9107548520004719437180227f,
1.6486845657792377944960219f,
586.5036549713060703425959730f,
cl_float expected_data3[5] = { 3.9578139676187164873802371f,
7.3404051605723232942594947f,
-0.0934815156297828550078870f,
0.4999777370923010424194188f,
6.3741788999092460674643357f,
for(int iterator=0; iterator<5; iterator++){
cl_mem output0 = clCreateBuffer(context, CL_MEM_WRITE_ONLY, DATA_SIZE*sizeof(float), NULL, &err);
cl_mem output1 = clCreateBuffer(context, CL_MEM_WRITE_ONLY, DATA_SIZE*sizeof(float), NULL, &err);
cl_mem output2 = clCreateBuffer(context, CL_MEM_WRITE_ONLY, DATA_SIZE*sizeof(float), NULL, &err);
cl_mem output3 = clCreateBuffer(context, CL_MEM_WRITE_ONLY, DATA_SIZE*sizeof(float), NULL, &err);
unsigned int count = DATA_SIZE;
err=0;
err = clSetKernelArg(kernel, 0, sizeof(cl_float), &defined_data0[iterator]);
err = clSetKernelArg(kernel, 1, sizeof(cl_float), &defined_data1[iterator]);
err |= clSetKernelArg(kernel, 2, sizeof(cl_mem), &output0);
err |= clSetKernelArg(kernel, 3, sizeof(cl_mem), &output1);
err |= clSetKernelArg(kernel, 4, sizeof(cl_mem), &output2);
err |= clSetKernelArg(kernel, 5, sizeof(cl_mem), &output3);
err |= clSetKernelArg(kernel, 6, sizeof(unsigned int), &count);
global = DATA_SIZE;
local = 1;
err=0;
err = clEnqueueNDRangeKernel(commands, kernel, 1, NULL, &global, &local, 0, NULL, NULL);
clFinish(commands);
cl_float* results0 = (cl_float *)clEnqueueMapBuffer(commands, output0, CL_TRUE, CL_MAP_READ, 0, sizeof(float)*DATA_SIZE, NULL, NULL, NULL, &err);
cl_float* results1 = (cl_float *)clEnqueueMapBuffer(commands, output1, CL_TRUE, CL_MAP_READ, 0, sizeof(float)*DATA_SIZE, NULL, NULL, NULL, &err);
cl_float* results2 = (cl_float *)clEnqueueMapBuffer(commands, output2, CL_TRUE, CL_MAP_READ, 0, sizeof(float)*DATA_SIZE, NULL, NULL, NULL, &err);
cl_float* results3 = (cl_float *)clEnqueueMapBuffer(commands, output3, CL_TRUE, CL_MAP_READ, 0, sizeof(float)*DATA_SIZE, NULL, NULL, NULL, &err);
cout.precision(10);
cout << fixed << "Expected result:\\t" << "erf( " << defined_data0[iterator] << " ) = " << expected_data0[iterator] << endl;
cout << fixed << "Calculated result:\\t" << "erf( " << defined_data0[iterator] << " ) = " << results0[0] << endl;
cout << endl;
cout << fixed << "Expected result:\\t" << "erfc( " << defined_data0[iterator] << " ) = " << expected_data1[iterator] << endl;
cout << fixed << "Calculated result:\\t" << "erfc( " << defined_data0[iterator] << " ) = " << results1[0] << endl;
cout << endl;
cout << fixed << "Expected result:\\t" << "tgamma( " << defined_data1[iterator] << " ) = " << expected_data2[iterator] << endl;
cout << fixed << "Calculated result:\\t" << "tgamma( " << defined_data1[iterator] << " ) = " << results2[0] << endl;
cout << endl;
cout << fixed << "Expected result:\\t" << "lgamma( " << defined_data1[iterator] << " ) = " << expected_data3[iterator] << endl;
cout << fixed << "Calculated result:\\t" << "lgamma( " << defined_data1[iterator] << " ) = " << results3[0] << endl;
cout << endl;
cout << "-------------------------------" << endl;
cout << endl;
system("PAUSE");
return 0;
[/cpp]
Expected results were calculated on CPU with c++ math.h functions, and compared with wolfram alpha to make sure they were right.
Here are some screenshots I took from this program execution:
On Intel HD 4000
On AMD Radeon HD 6570 and NVIDIA Quadro 600
And TY in advance.
Ben_A_Intel
Hi Vanessa,
I believe I have reproduced all of these issues.  A few of them were already fixed.  If you aren't using the latest driver, you may try upgrading to see if that helps.  The others are fixed internally, but it may be some time before a driver is released with the fixes.
Thanks!
  -- Ben
Vanessa_O_
Hi Ben,
Thanks for help. I tried the driver version 15.31.17.3257, from 09/11/2013, and some of the values were fixed, but some weren't.
Is there an estimated time for the corrections to be released?
(A screenshot of the same program running on the latest driver)
Thanks for help! :)
Ting_Q_
Sorry for reviving an old thread - I can confirm that lgamma still gives incorrect results for mobile HD 4000 using the latest stable driver (dated 5/21/2014) on Windows 8.1 64bit. Will a future release fix this problem?
We are university researchers working on using GPU to write efficient MCMC sampling algorithms. lgamma is a vital function for these problems. It would be great if our tools can be used by colleagues wit Intel processors! Thanks in advance.
