OpenCL* for CPU
1733 Discussions
Xeon E5-2690 v3 doesn't report correct OpenCL Max Compute Units
allanmac1
Here's a puzzling situation.
Different drivers and architectures (x86 vs. x64) report a different "max compute units" value on a dual Xeon E6-2690 v3 workstation (2 x HyperThreaded 12-core Xeons).
The new Visual Studio Code-Builder "Platform Info Tree" reports 32 compute units on both the 1.2 and 2.1 devices (incorrect).
The older standalone _x86_ Code-Builder reports 32 on both the 1.2 and 2.1 devices (incorrect).
The _x64_ Code-Builder reports 48 on both the 1.2 and 2.1 devices (correct).
The Nsight OpenCL System Info window reports 48 on both devices (correct).
Jeffrey_M_Intel1
Thanks for this report.  Some questions:
  • We've just released a new SDK (R3).  Do you still see the problem in the Visual Studio code-builder plugin with the latest R3 SDK version?
  • What version of Visual Studio are you using?
  • What info do you get from clGetDeviceInfo for CL_DEVICE_MAX_COMPUTE_UNITS?  (You can check with the Capsbasic sample.  Should be correct, but it will be helpful to verify.)
allanmac1
  • This was with R3 installed.  The VS2015 code builder plugin only reports 32 compute units.  The EOL'd standalone Code Builder x86 also only reports 32 compute units.
  • VS2015 Pro
  • CL_DEVICE_MAX_COMPUTE_UNITS is what the Nsight System Info panel uses and it reports 48 units ... but is this related to x64 vs. x86?
Jeffrey_M_Intel1
Thanks for the additional info.  Not sure if there is a relationship to x64 vs x86, but I've got this filed as a potential bug so we can continue looking from here.  Thank you for your help with making our tools even better.
