OpenCL* for CPU
clBuildProgram segmentation fault when -g build option specified
Noah_R_
This demonstrates a segmentation fault experienced upon calling clBuildProgram() when this particular OpenCL program is compiled with the "-g" build option.
My setup:  Ubuntu 13.04, Intel OpenCL intel/opencl-1.2-3.0.67279
Execution is on CPU device: Intel(R) Core(TM) i7-3615QM CPU @ 2.30GHz
Build Command:
[bash]g++ -o ./debug_symbols_seg_fault -g debug_symbols_seg_fault.cpp bugDemoSupport.cpp -I $OCL_INC_DIR -L $OCL_LIB_DIR -lOpenCL [/bash]
Run Command:
[bash]./debug_symbols_seg_fault [/bash]
Or, if you need to supply a different OpenCL platform index or device index, see [bash]./debug_symbols_seg_fault -h [/bash]
I see a segmentation fault upon call to clBuildProgram().
If you edit debug_symbols_seg_fault.cpp line 51 to remove the "-g" debug symbols flag from the buildOptions string, recompile, then re-run, the segmantion fault does not occur.
I tried a much smaller kernel but it did not reproduce this bug.  The attached full OpenCL program does work correctly in the context of a larger program on AMD and Apple OpenCL implementations.
Any suggestions?  I'd like to resolve this so that I can use the Intel debugging toolset.
Sidenote:  Wow.  Your forum does not accept files with .cl extension?
Raghupathi_M_Intel
Thanks for the reproducer. We'll take a look and get back to you.
Raghu
Noah_R_
Were you able to reproduce this bug?
Yuri_K_Intel
Hi, Yes, the bug is reproducible on our side. I will notify you about availability of the fix. Thanks, Yuri
Noah_R_
Has there been any progress on fixing this bug? The effect for me is I can't develop on the Intel OpenCL platform, because I can't troubleshoot my complex kernels using gdb.
Yuri_K_Intel
Hi, We have the fix in our development branch. Unfortunately, I can't say anything regarding when this fix will be available in a public release. I will update here once this is done. Thanks, Yuri
