OpenCL* for CPU
https://github.com/gammastorm/GammaOCL no debugging output
Thorsten_K_
here I try to code an own implementation of CopenCL for CPUs.
But even the debugging output is not printed.
Any ideas, why this is so ?
Thorsten Kiefer
Robert_I_Intel
Dear Thorsten,
If you have an issue with Intel OpenCL tools or drivers, please follow this check list when reporting it on the forum to ensure fast service:
  1. Please let us know what Processor, Operating System, Graphics Driver Version, and Tool Version you are using
  2. Please state steps to reproduce the issue as precisely as you possibly could
  3. If you are using command line tools, please provide the full command line
  4. If code is involved, it is great to create a small "Reproducer" sample and attach it to the message in the form of a zip file
  5. If you don't want your code to be seen by other forum users, please send me a private message
  6. Before posting, search the forum to see if someone already answered a similar question
Thank you!
Thorsten_K_
1. Intel Core 2 Duo, Peppermint 6, OpenGL renderer string: Mesa DRI Mobile Intel® GM45 Express Chipset x86/MMX/SSE2
2. strace clinfo :
close(4)                                = 0
munmap(0xb7736000, 4096)                = 0
open("/home/thorsten/NetBeansProjects/GammaOCL/GammaOCL/dist/Debug/GNU-Linux/libGammaOCL.so", O_RDONLY|O_CLOEXEC) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\2207\0\0004\0\0\0"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0775, st_size=124156, ...}) = 0
mmap2(NULL, 33900, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xb772e000
mmap2(0xb7735000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x6000) = 0xb7735000
close(4)                                = 0
4. https://github.com/gammastorm/GammaOCL/blob/master/GammaOCL/dispatch.cpp#L16
Output does not appear !!!
