OpenCL* for CPU
is this a bug with intel opencl compiler?
Weibin_T_
    My project work well if i compile it from opencl source file(test.cl) with clCreateProgramWithSource function. and save the cl program binary into an ir file(test.ir). When i recompile the cl program with clCreateProgramWithBinary , it gets an error while clBuildProgram is called.
     The same code works well both on NVIDIA and AMD GPU platforms, except the intel mic card(5110p).
     Is there something wrong with my code or intel opencl sdk?
     This problem has trapped me for a long time, can anyone help me? It is very important for me, thank you!
comile command:
/opt/intel/bin/icpc -g -o test  -I/opt/intel/opencl-sdk/include -L/opt/intel/opencl/lib64 -lOpenCL *.cpp
run command: ./test test.cl -debug
output:
 CL_PLATFORM_NAME:      Intel(R) OpenCL
 CL_PLATFORM_VERSION:   OpenCL 1.2 LINUX
run command: ./test test.ir
output:
 Error CL_INVALID_PROGRAM in oclLogBuildInfo Call !!!
Yuri_K_Intel
Hi Weibin T, What is the purpose of saving a binary with one additional byte? oclTest_0.cpp, Line 281: binary_size++; Commenting this line fixes the issue. Thanks, Yuri
Yuri_K_Intel
Weibin_T_
Thank you for your tips.
I have fix it.
