OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1732 Discussions
"IOC Engine crashed" when building kernel
Chris_Juelg
typedef union _float3 {
    struct {float x, y, z;};
} _float3;
__kernel void myKernel(
        _float3 offset,
        __global float * output ) {
    output[0] += offset.z;
When using KernelBuilder64 to build this kernel, I receive "Error occured, IOC Engine crashed" in an error popup, no compiler output in the Console and the following on stdout:
Bitcast type must not be aggregate
  %0 = bitcast i8* %pBuffer to %struct.anon
Instruction does not dominate all uses!
  %offset.coerce01.i = extractvalue %struct.anon %0, 0
  %5 = fadd float %4, %offset.coerce01.i
  store float %5, float addrspace(1)* %3, align 4
Broken module found, compilation aborted!
I use KernelBuilder64 3.0.0.1 from Intel® SDK for OpenCL* Applications XE 2013 on OpenSuse 12.2
The same kernel compiles without warning using the Nvidia OpenCL compiler. It also compiles as C99 with gcc when adapting the kernel function signature.
Just compiling this kernel in KernelBuilder works fine:
Setting target instruction set architecture to: Default
Intel OpenCL CPU device was found!
Device name:        Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Device version: OpenCL 1.2 (Build 67279)
Device vendor: Intel(R) Corporation
Device profile: FULL_PROFILE
Compilation started
Compilation done
Compilation succeeded!
Using a simple struct instead of the union of struct removes the error, but makes the rest of my program more complicated.
Chris_Juelg
i just noticed that the actual stdout message for the given kernel is:
  %1 = bitcast i8* %0 to %union._float3
  %5 = extractvalue %union._float3 %1, 0
  %6 = extractvalue %struct.anon %5, 0
  %8 = fadd float %7, %6
  store float %8, float addrspace(1)* %4, align 4
Yuri_K_Intel
Hi Chris, Indeed, I see this behavior on latest released version (XE 2013), but our internal development version builds this kernel just fine. So, please expect a fix to be available in next version of our SDK. I don't have any estimate about the date though. Thanks, Yuri
Yuri_K_Intel
Chris, Recently released version (XE 2013 R2, http://software.intel.com/en-us/vcsource/tools/opencl-sdk-xe) contains a fix for this issue. Could you please upgrade to it and verify the fix? Thanks, Yuri
Chris_Juelg
I just did the upgrade and the formerly problematic code runs like a charm.
Thank you for the info.
