OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1733 Discussions
some troubles in progress of Opencl SDK installation
jayne_f_
my system is Ubuntu 16.04LTS, the device name is  ivybidge.
I downloaded  "intel_sdk_for_opencl_2017_7.0.0.2511_x64.tgz". After extracting, the folder includes several docments ,like pset folder, rpm folder, install.sh, install_GUI.sh and so on.
the question is how can i use these resources to install SDK successfully?
according to some helps , in command window , I inputed  $(dirname $0)/install.sh --gui-mode $@ , but it showed  an error =====bash: syntax error near unexpected token '/install.sh'
I really don't know what's the meaning................
BTW, the "getting started " doc shows following:
mv install_SDK_prereq_ubuntu.sh_.txt install_SDK_prereq_ubuntu.sh
  sudo su
  $ ./install_SDK_prereq_ubuntu.sh
but i can't find the file named " install_SDK_prereq_unbuntu.sh_.txt".
Thanks for any feedback!
jayne_f_
There is a new question. After installation, I want to test it through a simple example, the software is so different from which on windows(just click *.exe). I can find the path where opencl_sdk is installed, but I don't know how can I 'open' , bulid, run the example on Opencl SDK.
