Hi all,
I'm having issues after upgrading from 10.18.10.3621 to 10.18.14 4206, on Lenovo x240 Haswell machine, Win8 and visual studio 2012 with the matching vc++ compiler 11, debug win32 config.
The surprising part is that one openCL app doesn't have any issues, while another, that accepts the previous as a DLL, while
running the same code that supposed to find the GPU devices, doesn't find the GPU. Both ran on the same machine, and the second got broken after installing the latest gfx driver.
Here's a small example, which is exactly the same between the two applications:
vector<cl_platform_id> platform = getClPlatforms(); //a wrapper for clGetPlatformIDs
bool foundPlatform = ! types.size(); // in case the list is empty we take the first platform
vector<cl_device_id> devIDFinal;
for (auto plat : platform)
cl_char version[256];
clGetPlatformInfo(plat, CL_PLATFORM_VERSION, sizeof(version), & version, NULL);
bool typeNotFound = false;
devIDFinal.clear();
vector<cl_device_id> devID = getClDevices(plat);
On the two different rans, "opencl 1.2" version is found, but getClDevices returns different result for that platform.
I've looked at the libs and dlls being loaded during both runs, and unless I've missed something, all of the headers/libs match.
Any guess?
P.S. I'm not sure if related, but One major change between before updating the gfx driver and after is the cpu-only experimental opencl2.0...
Thanks!
Danny.
Danny,
Does Lenovo allow you to install 10.18.10.4222 driver from here: https://downloadcenter.intel.com/search?keyword=4th+Generation+Intel%c2%ae+Core%e2%84%a2+Processors+with+Intel%c2%ae+HD+Graphics+4400 or does it force you to install its own custom driver?
Could you please provide both Apps? You could send me a private message.
One possibility is that one of the apps don't see all the DLLs that the other one does. Try to print the environment for both Apps and see if the content of environment variables match. Without some kind of reproducer it is hard to tell what is going on.
