Hello, @Kronoslce
Please be informed that I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
Also, please be aware that Intel® XTU was designed to work with X or K processors (unlocked processors) and, you have a U processor, the Intel® XTU will not install on your laptop because is not compatible. You can verify here the supported processors by this tool: Intel® Extreme Tuning Utility (Intel® XTU)
Jocelyn M.
Keşke benimkide destekleseydi iyi olurdu yardımlarınız için teşekkür ederim
Hello, @Kronoslce
Thank you for your reply. I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
The Intel® Extreme Tuning Utility (Intel® XTU) is used to overclock, monitor, and stress a system. This application is supported with unlocked processors (K- and X-series) only, since these processors can be overclocked and stressed out and it won't be installed or supported on other processors due to the reason mentioned above.
Jocelyn M.
merhabalar öncelikle kolay gelsin işlemcim intel core 12600k intel extreme tuning utility kurulmuyor 0x80070643 hatası veriyor bunun nedeni nedir yardımcı olursanız sevinirim
