Processors
13533 Discussions
核显无法使用
ZY-X
硬件配置
CPU:i3-10850K9(带核显)
主板:微星Z490
系统:WIN11专业工作站版
目的:想启用核显功能
1:我的电脑在不插独立显卡的情况下,主板上的DRAM自检灯亮着,进不去系统,已经尝试将四根内存拔下自取金手指,插单根相互交换,检查灯亮着,只有插上独立显卡自检灯灭,才能进系统。
2:在插上独立显卡的情况下,进入BIOS将核显打开,主板DRAM灯也亮了,进不了系统。
已试用解决方案解决方案,将硬件拔出问题重新安装,重装系统任驱动安装不上上述问题,可判断不是内存问题,可解决DRAM灯会亮。
Jean_Intel
Hello ZY-X,
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Since you mentioned that you can't access your system, and you receive an error light code pointing out that there is an error with the RAM. As this indicated that the RAM may be faulty, my recommendation is to use another set of RAM or contact your motherboard manufacturer to check the LED codes they can also provide a hardware check to test if there is any problem with your motherboard.
Jean O.
