I am wondering if a 10th gen core processor would be compatible with DDR4 memory with a lower frequency than the one indicated at the processor's spec sheet. To be specific, I am wondering if a i3 10100 would function well along with 4x 4GB sticks of DDR4 2400mhz memory on a motherboard supporting this ram frequency (e.g. the MSI b460m bazooka)?
Thank you in advance for your answers.
Most systems will automatically detect the slower RAM and configure the processor to work at the DRAM's maximum frequency. DDR4/2400 has an 18% lower peak transfer rate than the fastest supported DRAM (DDR4/2933), but the maximum sustainable transfer rate is probably only about 15% lower. Most of the time your system will not be limited by memory bandwidth, so in practice you will see very little difference. Overall, performance with 16GiB of DDR4/2400 is likely to be better than with 8GiB of DDR4/2933 memory.
