Using an i5-4670K. See fwts Log:
microcode: Check if system is using latest microcode.
Test 1 of 1: Check for most recent microcode being loaded.
This test verifies if the firmware has put a recent revision of the microcode
into the processor at boot time. Recent microcode is important to have all the
required features and errata updates for the processor.
FAILED [MEDIUM] MicrocodeNotUpdated: Test 1, The kernel did not report that CPU
0 has had a microcode update. The current firmware is revision 0x9 and probably
has not been updated.
1 has had a microcode update. The current firmware is revision 0x9 and probably
2 has had a microcode update. The current firmware is revision 0x9 and probably
3 has had a microcode update. The current firmware is revision 0x9 and probably
Hi Iyeru,
Can you tell us where in the bios do you receive the message? Is it possible to for you to post a clear image?
Here's the full fwts log, since it's the only place that it says it (The BIOS itself doesn't say it. But when queried by the fwts script, the BIOS reports it.)
http://pastebin.com/CaNgwUpa fwts - Pastebin.com
I cannot set anything that says To be filed by O.E.M. since I had the processor and motherboard instaleld at a local computer store.
Hi Iyeru,
I am having problems opening the link. Can you please copy and paste the information here?
