Battery not detected
P-nut
First time posting not sure where i was suppose to post my problem at..
i have a Asus X551MA laptop
windows 10
it says "battery not detected"  yet my taskbar notification says "battery 100%"
when i umplug my laptop it goes dead immediately...no power..
i tried to download the battery detection tool but got error that no battery was detected..
went to my device manager and uninstalled both
Microsoft AC Adapter
Microsoft ACPI-Compliant Control Method Battery
and restarted..
did not fix my problem
AlHill
And, this is an Intel problem because...?
You need to contact ASUS for support.
P-nut
Excuse me..
I was here updateing drivers and thought maybe someone here could offer a suggestion..
Didnt say it was a intel problem...
But believe this..
I wont post here again and F.Y.I...
For a " super user" your attitude sux..
More like a " super loser" i think
AlHill
Intel did not make the laptop.
Intel did not make the battery.
Batteries do go bad.
Battery circuitry does go bad.
Drivers have nothing to do with this.
Asus is responsible for your warranty and hardware support.
Asus can replace your battery, or tell you what battery to get.
Contact Asus for support.   And, just because you made a mistake do not bring your attitude and insults to the forum.
Esteban_D_Intel
Hello P-nut,
We understand that you are experiencing some battery problems with your laptop.
As you may know, when talking about hardware/components failure we would always recommend checking with your laptop manufacturer for a proper inspection of the components and discard a possible hardware failure.
Based on the description of you issue, seems that the battery of your laptop may be failing. As AlHill states you would need to contact your laptop manufacturer (in this case ASUS*) for further assistance.
I really hope that you can resolve this situation with them.
As you required assistance from your manufacturer, we will proceed with the closure of your inquiry. However, If you need any additional information, please submit a new question and we will be glad to assist you.
Please consider that this thread will no longer being monitored
Esteban D.
Intel Technical Support Technician
