Processors
14633 Discussions
Brand string test fail
EEdua1
today i run a diagnostic routine on my processor and the processor diagnostig tool give me a brand string fail, heres the details
system Information
Processor Name: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
Processor Information: Intel64 Family 6 Model 23 Stepping 10
Number of Physical Cores: 2
Number of Logical Cores: 2
Installed System Memory: 4 GB
Operating System: Microsoft Windows 10 Pro 64 bits
Graphics Information: NVIDIA GeForce GT 610
System Product: TO BE FILLED BY O.E.M.
System BIOS: 5HKT39AUS
System Serial Number: MJ52046
--- IPDT64 - End Time: 8/9/2016 6:29:50 p. m.
--- IPDT64 - Result: Fail
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 8/9/2016 6:39:34 p. m.
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Thu Sep 08 18:39:39 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Thu Sep 08 18:39:41 2016
Total Time: seconds: 2
Temperature Test
Start Time: Thu Sep 08 18:39:42 2016
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 57 degrees below max
End Time: Thu Sep 08 18:40:19 2016
Total Time: seconds: 37
CPU Brand String Test
Start Time: Thu Sep 08 18:40:19 2016
Test Result - FAIL
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
Brand String Test Failed!!!
Total Time: seconds: 0
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
--- IPDT64 - End Time: 8/9/2016 6:40:20 p. m.
please i need help!
Hi blazeac,
Your system is older now; the drivers and BIOS for your board are not prepared for Windows 10. I believe our Intel® Processor Diagnostic Tool is not recognizing properly the processor specifications.
I suggest you the following workaround:
CPU brand string test library determines which Intel® CPU is being tested using one of two modes, presence test mode or verification mode. The mode being used is determined by the SkipConfig parameter in the IPDTconfig.xml configuration file found in the IPDT folder.
More details on page 20 of The Intel® Processor Diagnostic Tool Windows® - User Guide
http://www.intel.com/content/dam/support/us/en/documents/processors/sb/theintelprocessordiagnostictoolinwindowsuserguider.pdf http://www.intel.com/content/dam/support/us/en/documents/processors/sb/theintelprocessordiagnostictoolinwindowsuserguider.pdf
Verify if you are running the processor at 2.6 GHz and memories at DDR3 800/1066/1333, DDR2 667/800 in the BIOS.
Let me know how it goes.
Mike C
