Hai,
i am facing an CPU FAN error,
My system configuration:
Asus H97 pro MB
Intel i3 4150 processor
Transcend 4GB ram
1 TB seagate HDD, i purchased 1 month before
Problem:
My CPU fan start after 20 seconds or even take more time,
Different Test cases Result:
1.Fan starts after 22 sec,
2.Fan starts after 35 sec,
3.Fan starts after 10 sec,
some time the system entered into OS and my ASUS suite reports an error CPU FAN at zero RPM
please give solution to my problem
- Tags:
- CPU
Please check there are no objects obstructing the fan blades. You may test the fan connecting its cable to a different (chassis) fan header besides the CPU fan header, just to discard a motherboard issue.
If the issue persists, contact the nearest http://www.intel.com/p/en_US/support/contactsupport Intel support team in order to get a fan replacement.
Thanks for your Reply.Yup, i checked with Chas fan port and the problem exists.So i need to replace processor fan
![](/skins/images/98E68944C1FF703B8AC50091329B92AF/responsive_peak/images/icon_anonymous_message.png)
