The description of FPREM in Volume 2 of the Software Developer's Manual (075US) contains 'Table 3-31. FPREM Results' that contains '**' where ST(0) is finite and ST(1) is zero, and the notes say:
** Indicates floating-point zero-divide (#Z) exception.
However, the list of exceptions under 'Floating-Point Exceptions' for this instruction does not include #Z, and it says that #IA is raised if the modulus, i.e. ST(1), is 0. Also, Volume 1, Section 8.5.3 Divide-By-Zero Exception (#Z), does not mention FPREM.
The documentation appears inconsistent. Can FPREM set #Z?
Hello Phil_Clayton,
1. Can you share the file/PDF where you read that information?
2. What is the model name of the Intel device related to this inquiry?
3. Are you developing software or hardware? Can you share more details?
Deivid A.
Hi Deivid,
Thanks for your response. To answer to your questions:
By Software Developer's Manual I meant Intel® 64 and IA-32 Architectures Software Developer Manuals . Each volume I referred to is available as a whole PDF from the Intel website as follows:
The query relates to Intel 64 and IA32 processors. There is no specific processor model related to this query.
Neither. I am performing an independent assessment of safety critical software for the purposes of certification using static analysis techniques.
Phil
Hello Phil_Clayton,
Thank you for the information provided
Deivid A.
Hello Phil_Clayton,
I would like to let you know that we have a specific website for this kind of issue and product, it is called the Intel® Resource and Design Center (RDC). There you will receive the appropriate support on this and other concerns you may have related to this product.
Here you will find the links to access the website:
- https://www.intel.com/content/www/us/en/documentation-resources/developer.html#panel-top-resources|most-popular
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Thanks for the links.
