Processors
15131 Discussions
Can Intel D945GCCR for desktop, Pentium(R) Dual-Core CPU T4500 for notebook processors be replaced with the ones with virtualisation feature and perform as well as before? can you recommend suitable processors for replacing?
qsu
Dear Intel Community,
(for Intel Processor)
I bought a desktop PC in about 6 years ago. The core product is D945GCCR, version is AAD78647-301, cpu is Intel(R) Pentium(R) D CPU 3.20GHZ. It has no virtualisation feature.
Can this core/cpu be replaced with one with virtualization feature, without replacing any other components and still perform well as before? can you recommend suitable Intel core/cpu/processor for this purpose?
in the Ubuntu terminal, run the below commands and get the corresponding return:
1) dmidecode | grep -A4 'Base Board Information'
Manufacturer: Intel Corporation
Product Name: D945GCCR
Version: AAD78647-301
Serial Number: BTCR71100WJ1
2) dmidecode -t 4 | grep Socket
Socket Designation: LGA 775
from the return of 2), the socket type is LGA 775, can this verify that the motherboard of this desktop PC support virtualization (it was bought in about 6 years ago)? if not, how to check whether or not the motherboard of this desktop PC support virtualization?
By the way, my Compaq 620 Energy Star notebook was bought about 2 years ago, and the processor is Pentium(R) Dual-Core CPU T4500, but without virtualization feature as well. Can it be replaced with one with virtualization feature and perform well as before? can you help to recommend a suitable one with virtualization feature?
Thank you very much for your help !
DArce
Valued Contributor III
For the Intel(R) Desktop Board D945GCCR you may use the Intel(R) Pentium(R) D 940 (sSpec SL95W only) processor which supports Intel® Virtualization Technology. The rest of Intel(R) Pentium(R) D that support Intel® Virtualization Technology are not compatible with the revision of motherboard you have. For this you can check the motherboard compatibility list here:
http://www.intel.com/support/motherboards/desktop/d945gccr/sb/CS-026626.htm Intel Desktop Board D945GCCR | Supported processors
For information on what each processor supports you can check for the processor model here:
ark.intel.com
Concerning the laptop system you mentioned, there might be many different options for you to upgrade or replace your processor with. We recommend contacting the computer manufacturer as they have set the valid compatibility list between the computer, the BIOS and the available processors in the market. The system manufacturer should also provide the specifications on what technologies from the processor might or might not be supported.
Please bear in mind that what limits the compatibility is the computer itself (motherboard and bios) not the processor. The motherboard requires to have the proper micro code to manage the processor, if not, the system will not work, and it is the computer manufacturer or Original Equipment Manufacturer who develops the BIOS to include the microcode for the processor
qsu
dear diego_intel or other intel staff,
thanks for your help.
i check the processor for the desktop board (D945GCCR), it is "x86 family 15 model 6 stepping 5 genuineintel 3192 mhz" (i can't identify the processor number of this CPU, either with "cat /proc/cpuinfor" or "dmidecode". please help on how to identify the processor number for this CPU) and the socket type is LGA775. is this processor support virtualization? if not, as you recommend, replace it with the 940 (SL95W) onto the same motherboard, can the whole system support virtualization (including motherboard, BIOS)? the 940 (SL95W) support PLGA775 socket type, but the current "x86 family 15 model 6 stepping 5 genuineintel 3192 mhz" processor support LGA775, does this matter?
The BIOS in the motherboard at the moment has no virtualization enable/disable option (BIOS version/Date is CR94510J.86A.0045.2007.0418.1532, 4/18/2007; SMBIOS version is 2.4). what is the latest version of BIOS can be upgraded to for this motherboard for virtualization feature?
are there any other things need to check before going to buy a 940 processor to replace the current one for virtualization for the whole system? when replacing the current CPU with the 940 (SL95W) one, the cooling component need to be replaced as well or can use the current one (the power consumption of these two CPUs are different)?
this type of motherboard and processor might be too old, but please do help me to answer the above questions, and give me the firmed advice on how to upgrade the whole system to enable virtualization feature. i don't have enough budget to purchase the new computer system, so perfer to upgrade.
thank you very much for your help in deed !
DArce
On older motherboards, when the processor installed was not able to support Intel® Virtualization Technology then the option was simply not shown in the system BIOS, however being this an old motherboard, it would be hard to know if the reason is that actually the motherboard does not support this feature at all.
Please bear in mind that this product has reached its End of Interactive Support so Intel no longer provides interactive support for this product via telephone, chat or e-mail. Being this an old product, there might be a possibility that it does not support Intel® Virtualization Technology at all, you would need to test and see.
The latest BIOS for that motherboard is 0060 available at:
Download Center
Now, concerning the processor, you can use the Intel(R) Processor Identification Utility which will identify the processor and tell you what features it will support, so this will show you under the advanced technologies tab if the processor supports Intel® Virtualization Technology or not:
http://www.intel.com/support/processors/tools/piu/sb/CS-014921.htm Intel(R) Processor Identification Utility | Intel(R) Processor Identification Utility download for Windows*
qsu
Dear Diego,
Thanks for your help, much appreciated.
I have already upgraded the BIOS to the latest version 0060 a few days ago, but haven't upgraded the CPU (it needs to be ordered from eBay or Amazon and will take more than a week). But there is no option to disable/enable virtualization in the latest BIOS.
Can we say the desktop board D945GCCR not support virtualization at all, or it still may support virtualization, but the BIOS has no that option?
If the CPU not support virtualization, does the BIOS has the option to disable/enable virtualization? Not quite sure what is the logic of the design for the BIOS utility program?
Sorry for the desktop board being too old, but if can identify that it can support virtualization, then just need to upgrade the CPU.
When get the above issues sorted out, I can decide whether to upgrade or just buy another one.
Thanks for your help.
DArce
Use Intel(R) Processor Identification Utility available here:
For information on how to use this software check the video here:
http://www.youtube.com/watch?v=FuCFouFQWDk Intel® Processor Identification Utility - YouTube
From there check if the processor you have support Intel® Virtualization Technology or not. If it does then the option to enable VT should be displayed in your system BIOS.
qsu
Dear Diego,
Thanks for your reply.
In the page of http://ark.intel.com/products/34687/Intel-Desktop-Board-DQ45C ARK | Intel&# 174; Desktop Board DQ45CB, it shows that Intel desktop board DQ45CB support VT-d (not VTX), but in the page of http://www.intel.com/support/motherboards/desktop/sb/CS-030922.htm Desktop Boards — Compatibility with Intel� Virtualization Technology (Intel� VT) , it looks like that it supports both VT-d and VTX. what is the correct information?
I find an Intel desktop board (DQ45CB) + Intel Core 2 Duo Processor E7500 (3M Cache, 2.93 GHz, 1066 MHz FSB), and would like to use them to replace the ones in my current computer system for virtualization, and keep on using the remaining parts. hopefully they can fit into my current computer system, and the whole computer system can support virtualization after upgrade.
DArce
Intel® Virtualization Technology VT-x is a feature of the processor itself, which is used by the motherboard to enable Intel® Virtualization Technology VT-d on its operation. So, if the processor you install in that motherboard supports VT-x, then the motherboard basically will support it and add support for VT-d too.
qsu
Thanks Diego, do you know the link for the Intel Server Boards that support Virtualization technology, and the other relevant information about server system supporting virtualization? thanks.
DArce
Servers can be a completely new ground. You can seek for such information at
For a list of processors with Intel® Virtualization Technology support you can refer to:
http://ark.intel.com/products/virtualizationtechnology http://ark.intel.com/products/virtualizationtechnology
qsu
Dear Diego,
I see some computer systems in www.trademe.co.nz 1) http://www.trademe.co.nz/Browse/Listing.aspx?id=656079430 http://www.trademe.co.nz/Browse/Listing.aspx?id=656079430 2) http://www.trademe.co.nz/Browse/Listing.aspx?id=656079606 http://www.trademe.co.nz/Browse/Listing.aspx?id=656079606 3) http://www.trademe.co.nz/computers/desktops/no-monitor/auction-656079414.htm http://www.trademe.co.nz/computers/desktops/no-monitor/auction-656079414.htm 4) http://www.trademe.co.nz/Browse/Listing.aspx?id=657324576 http://www.trademe.co.nz/Browse/Listing.aspx?id=657324576.
All of them are with Intel motherboard with Intel H61 chipset and Intel CPU. All the systems look like do support VT.
My question is that do all of them support Linux OS, e.g. Ubuntu 12.04, both 32/64 bits desktop GUI and server?
Moreover, Intel DQ35JO + E8400 CPU support VT-D? What can VT-D actually do? Can you give some example? Is it that VT-D support nested VM creation?
DArce
For information on vt-d you can refer to this article:
http://software.intel.com/en-us/blogs/2009/06/25/understanding-vt-d-intel-virtualization-technology-for-directed-io http://software.intel.com/en-us/blogs/2009/06/25/understanding-vt-d-intel-virtualization-technology-for-directed-io
Keep in mind that Intel(R) Desktop Boards support only desktop operating systems, so server edition operating systems are not supported. Concerning Linux* support, this is only supported by the operating system distributor directly.
qsu
thanks Diego,
in only have desktop board PC, and installed both ubuntu desktop and server OS onto it, and both working. for ubuntu desktop and server OS, can both of them install and supported by desktop board PC?
thanks.
DArce
We do not validate server operating systems on desktop motherboards, for that you need to use a server/workstation motherboard to use a validated operating system. And Linux* compatibility depends on the operating system distributor so we do not check if a given Linux* flavor is supported in these motherboards, so you need to check with the respective Linux* distro.
qsu
Dear Diego,
if the desktop board isn't made by Intel, but use Intel CPU, or the desktop board is made by Intel, but the CPU isn't, how to know whether they're compatible with each other. Are there any tools, URL links to check for these?
are ASUS P5QPL-AM Motherboard and Intel E6750 CPU compatible with each other and the whole computer system support VT?
thanks.
qsu
Dear Diego,
When decide whether a motherboard and CPU (whether or not they are made by the same manufacturer) could be used together to build a computer system and support the features they both have (e.g. virtualization technology support), what is the process and what information need to be checked with before the conclusion reached?
For example, to decide whether one motherboard and CPU (whether or not they are made by the same manufacturer) can build a computer system to support VT, need to check both support VT, BIOS support VT, both compatible with each other. Is this enough? Is it need to check the socket type match, chipset match? How to know what chipset a CPU belongs to? if a motherboard and CPU compatible and both support VT, can we say the computer system built by them support VT (if not consider other components, like RAM etc.)? Are there any tools or URL links to check these information?
What does "motherboard and CPU compatible with each other" mean? does this compatible include the socket type matchable and chipset matchable?
thanks,
Q.S.
DArce
Who determines compatibility is the motherboard manufacturer respectively and this is not a matter of socket type or based on the fact that the motherboard is using a similar processor. So, you always need to check with the motherboard manufacturer to see if the processor you would like to use is compatible with the motherboard.
Concerning Intel® Virtualization Technology support you need to check with the motherboard manufacturer to see if the motherboard supports Intel® Virtualization Technology.
For processors, you can easily check for the processor model on http://ark.intel.com/ ark.intel.com and see what technologies are listed as supported there.
qsu
Dear Diego,
Thanks for the help.
If there are some assisting tools, then we may be able to get things sorted by ourselves, so don't need to ask the manufacturers so often.
From your reply, it looks like that it is better to ask manufacturers for the compatibility, features etc of motherboard and CPU.
Now I need the help to confirm below:
1) Intel DQ35JO and Intel E8400 CPU are compatible and both support VT-X and VT-D.
2) ASUS P5QPL-AM and Intel E6750 CPU are compatible and both support VT-X (not VT-D).
3) For the CPUs E8400 and E6750, and motherboards DQ35JO and ASUS P5QPL-AM, to better utilized the features, resources and performance offered by the motherboard and CPU, is the combination of DQ35JO + E8400 and ASUS P5QPL-AM + E6750 better or the combination of DQ35JO + E6750 and ASUS P5QPL-AM + E8400 better?
4) Intel DQ35JO and DQ965CO, which one is better?
5) Intel DQ35JO and DQ965CO support Linux OS, e.g Ubuntu 12.04.3 desktop GUI and server?
Q.S.
DArce
There are tools available for this on Intel(R) products. That is why I have mentioned already to use ark.intel.com
From the following links you can check the features on these processors:
http://ark.intel.com/products/33910/Intel-Core2-Duo-Processor-E8400-6M-Cache-3_00-GHz-1333-MHz-FSB?q=E8400 http://ark.intel.com/products/33910/Intel-Core2-Duo-Processor-E8400-6M-Cache-3_00-GHz-1333-MHz-FSB?q=E8400
http://ark.intel.com/products/30784/Intel-Core2-Duo-Processor-E6750-4M-Cache-2_66-GHz-1333-MHz-FSB?q=E6750 http://ark.intel.com/products/30784/Intel-Core2-Duo-Processor-E6750-4M-Cache-2_66-GHz-1333-MHz-FSB?q=E6750
If you need to check Intel(R) processors and motherboards compatibility you can refer to:
http://processormatch.intel.com/CompDB/ Intel® Processors and Boards Compatibility Tool - Home Page
DQ35JO and DQ965CO are End of Interactive Support products which are no longer supported by Intel. Only technical support on them is available as technical information available on the web site.
We do not compare Intel(R) products based on their performance, however you should think that being a newer product, the performance should be better.
As already mentioned, we do not validate server operating systems on desktop boards, and for compatibility on Linux* operating systems, you need to contact your Linux distributor.
If you have further questions not related to the original topic on this thread, please create a new topic or check for your the information you need through a pre-sales service at http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
