Processors
15854 Discussions
Carte mere LGA 1155
Dauphins
Bonjour ,
je recherche un intel compatible windows 11
j ais une carte avec LGA  1155
Peut avoir un processeur compatible avec ma carte mere ??
avez vous la Ref d un processeur pour intel pour fonctionner avec windows 11
Faut il remplacer la machine ??
Merci a vous Cordialement M LEFEVRE
AlHill
I do not believe you will find any 8th gen or later processors that use socket 1155.
You can check this list for one:
https://ark.intel.com/content/www/us/en/ark/search/featurefilter.html?productType=873&1_Filter-SocketsSupported=3636
and you can check microsoft's compatible list:
https://learn.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
You would do better by replacing the motherboard with one that supports windows 11.  Specifically, an 11th gen or later, as support for 10th gen and lower is rapidly becomming unsupported.
