I bought ASUS UX303LB with 1tb spin disc Harddisk and would like to upgrade to 2tb Harddisk. So, I ask ASUS's staff and found out "Chipset Intel® Skylake BGA (2 in1 )" will do not know this size of Harddisk.
Can anyone confirm me about above blocking reason? Many thanks.
Hello Dome,
Thank you for contacting Intel Communities.
The PCH on the chipset installed on your laptop supports data volumes up to 256 TB, therefore; there isn't any restriction from the chipset side to upgrade to a 2 TB HDD.
On the other hand, I would check with the manufacturer (Asus) for any restriction from their side.
Please check http://www.intel.com/content/www/us/en/support/technologies/000005807.html this article for more information.
Hope this information helps.
JC
Hello Dome,
I was reviewing this thread and I wanted to know if you need further assistance?
If so, please don't hesitate in replying to this post.
JC
Hi, JC
Many thanks for your helping.
I just receive some answer from ASUS's staff as follows:-
1. They block the maximum of HD capacity (up to 1TB).
2. Reason: Prevention from Heat, Notebook design limit (WD and Seagate have 2TB HD in 7mm size today), Chipset durability.
If you can do some favor for me, Please tell me how to recheck it? Such as BISO check or only try to install 2TB HD. for compatibility or try to connect any size of > 1TB HD via USB3 port.
Thanks again.
Dome.
HW Spec
UX 303 LB
CPU
Intel® Core™ i7-5500U 1.8GHz
Intel® Core™ i5-5200U 1.6GHz
NV 940M + Intel® HD Graphics 4400
Main Memory
DDR3L 1600MHz 4GB (on board) + 2G / 4G/ 8G Slot Dim
Display
13.3" 16:9 178 FHD (1920 x 1080)
QHD+ (3200*1800)
Card Reader
SD
Storage
Pure 7mm HDD up to 1T
Hybrid HDD: 500G HDD +8G SSD
SSD: up to 256G
Connectivity
802.11 a /g/n & 802.11 ac
External cable support 10/100 Mbps Ethernet
Built-in Bluetooth v2.1 + EDR
BT 4.0 support (on WLAN+ BT 4.0 combo card)
Camera
HD 720p CMOS module
OS
Windows® 8.1 Home Basic 64 bit
Windows® 8.1 Home Premium 64 bit
Windows® 8.1 Professional 64 bit
<td style="font-family: arial, sans-serif;" valig...- Mark as New
Hi Dome,
Asus confirmed what I mentioned earlier; even though the chipset may support certain features/options, the OEM may restrict them.
You shouldn't have any issues connecting an external HDD via the USB3 port, however; you may run into some incompatibility with some drives (you will need to confirm compatibility with Asus).
JC
