17083 Discussions
Compatibility question - memory card DDR3
EKrae
Hi! I'm a girl from Russia and may be I'm asking a wrong question in a wrong place but where i can ask - will a new memory card fit my mother board for sure?
Memory card - KINGSTON KVR16S11S8/4 DDR3 - 4Гб 1600, SO-DIMM, Ret (http://www.kingston.com/datasheets/KVR16S11S8_4.pdf http://www.kingston.com/datasheets/KVR16S11S8_4.pdf - I guess it's it)
Mother board - Mobile DualCore Intel Pentium B950, 2100 Mhz (21x100), Sandy Bridge.
Chipset - Intel Cougar Point HM65.
I checked characteristics here... - http://ark.intel.com/products/55627/Intel-Pentium-Processor-B950-2M-Cache-2_10-GHz Intel® Pentium® Processor B950 (2M Cache, 2.10 GHz) Specifications
They are ok. But in reviews some people wrote that they had compatibility problems with some proc. for example, with Arrandale (http://www.citilink.ru/catalog/computers_and_notebooks/parts/memory/762439/rev23035/# readreview Обзор о товаре модуль памяти KINGSTON KVR16S11S8/4 DDR3 - 4Гб - интернет-магазин СИТИЛИНК).
Why that may happen?
I want to add this card to this one -
I would be really appreciate any answer.
AJana1
Valued Contributor I
Hello Girl from Russia, Evi
Because the memory controller has been integrated into processor, rather than located on the mainboard, so this 4GB is a soft limitation. Pentium B950 supports DDR3 memory up to 16GB. Such Notebook computer might provide two slots for memory modules, in other words, you could plug two memory modules onto your notebook computer. But please make sure that the desired memory modules are the normal DDR3 (not DDR3L, not DDR3U, not ECC memory modules, not Registered or Buffered memory modules, not AMD-exclusive memory modules found on China mainland market) and do not exceed 4GB per module. Any one meets such requirements would work well on your computer.
I wish this reply could solve your problem, good luck!
Aaron Janagewen
ppara5
"Mother board - Mobile DualCore Intel Pentium B950, 2100 Mhz (21x100), Sandy Bridge."
This is not a motherboard; it is a CPU. Run CPU-Z again and look at the Mainboard tab.
Why not buy another Samsung stick? Samsung actually manufactures its own DRAM chips, while Kingston buys DRAM chips from the actual manufacturers.
EKrae
It's true) I'm sorry)
Motherboard - Hewlett-Packard 3672
Computer model - Compaq Presario CQ57-380ER
Thanks a lot for information, i didn't know it.
But I was looking for a new Samsung stick and wasn't able to find any SODIMM in my city. Only with delivery - it takes about a week... I need it sooner.
EKrae
I also found this - http://support.hp.com/us-en/product/Compaq-Presario-CQ57-Notebook-PC-series/5145720/model/5194286/document/c03091692/ Compaq Presario CQ57-380ER Notebook PC Product Specifications | HP® Customer Support
Is that mean that i cannot add 4 Mb memory to 2 Mb existed? 4 is maximum for my board??
AJana1
Aaron Janagewen
ppara5
Janagewen is correct regarding the mismatch between the CPU which supports up to 16GB, and the motherboard which only appears to support up to 4GB. For some unknown reason HP added this restriction. I recommend contacting HP and asking them about this. Or ask in HP forums (hp.com, Forums, Notebook Forums, Notebook Hardware and Upgrade Questions). It is possible the 4GB limit cannot be exceeded, but it also might be a misprint or a soft limit (sometimes it works and sometimes it does not). You already have the latest BIOS (F.39). Do you know anyone with a spare 4GB SODIMM stick to try and see if the PC will recognize it?
AJana1
Well, I could not speak Russian, but see something like http://www.abris-nb.ru/detail/28177/15724/ Ноутбук HP Compaq Presario CQ57-380ER (QH760EA) ...
EKrae
Dear Aaron Janagewen and paramountain , thanks! you helped me a lot!
It was such a pleasure to read your professional answers and to get information I wasn't able to find myself
At the end I managed to find a shop with a noname not-packed 4 Gb DDR3 memory module and with a shop assistant agreed to let me try this module before buying it. So I came to the shop with the laptop and put this module inside. Windows found it and worked well and fast so I happily bought it!
Thank you, friends!
