Buen dia acabo de adquirir mi tarjeta grafica GIGABYTE GeForce RTX™ 3070 Ti GAMING OC 8G, y quiero instalarla en formato vertical mediante un cable de elevacion (RISER) PCI-E, mi tarjete madre GIGABYTE Z490 VISION D. Abos con compatibilidad pci-4.0
Consulta 01: ¿El cable de elevación pci-e debe ser pci-e 4.0?
Consulta 02: Si lo anterior es correcto esto podría generar algún conflicto debido a que mi procesador (Intel Core i9-10900K) no es compatible con pci-e 4.0.
Consulta 03: si existe algún conflicto con el procesador, la única opción es conectar los componentes mediante un cable de elevación pci-3.0 o existen otras opciones para evitar la pérdida de rendimiento de la tarjeta.
Contact gigabyte for support on their hardware.
Where does it say that GIGABYTE Z490 VISION D supports PCIe 4.0?
All the PCIe Buses I see there are 3.0
This motherboard has chipset Z490 and it says only supports 10th Gen CPUs
https://www.gigabyte.com/Motherboard/Z490-VISION-D-rev-1x/sp#sp
Support for PCIe 4.0 was introduced with 11th Gen CPUs and Chipsets... My understanding is that 400 Series Chipsets only support up to PCIe 3.0.
As an aside note, PCIe is backward compatible, PCIe 4.0 devices will work on PCIe 3.0 slots, but, yeah, I agree with AlHill, you need to discuss this with Gigabyte...
The https://www.asus.com/br/motherboards-components/motherboards/prime/prime-z590-p/techspec/
is compatible with SSD Team Group T-Force Carder Zero Z440 1TB M.2 NVMe PCIe Gen4 x4, TM8FP7001T0C311?
I can not install it.
@DMOliveira You can ask Asus questions regarding hardware compatibility with their hardware/motherboard.
