Hello, I recently bought a Core 2 Duo E8400 and I can't find out for sure if it is compatible with my nForce 570 SLIT-A V5.1 motherboard. Any help or info about required BIOS/drivers is greatly appreciated.
Please contact the motherboard manufacturer so they can provide you full information about compatibility between the Intel(R) Core(TM) 2 Duo processor E8400 and their motherboard, please keep in mind that the motherboard manufacturer is the one that determines the compatibility.
Thanks for the reply. I understand it's the burden of the manufacturer of the mobo to supply that information but I have not received a response from them so I thought I would try asking here.
According to the following link only 65nm Core 2 Duo's are supported (E4xxx & E6xxx Series).
http://www.ecs.com.tw/ECSWebSite_2007/Support/CPU_Support_Model.aspx?detailid=678&MenuID=69&LanID=0 http://www.ecs.com.tw/ECSWebSite_2007/Support/CPU_Support_Model.aspx?detailid=678&MenuID=69&LanID=0
