Processors
14581 Discussions
Core 2 Duo T6570 can be upgraded with which mobile cpu?
SMAUR2
i want to upgrade my cpu bt i am confused as thr r many Socket P processor, based on Penryn core as my current cpu core 2 duo t6570 has, suggest me for which one i can go from the list http://www.cpu-upgrade.com/CPUs/Intel/Core_2_Duo_Mobile/T6570.html http://www.cpu-upgrade.com/CPUs/Intel/Core_2_Duo_Mobile/T6570.html . some shortlisted cpus r http://www.cpu-upgrade.com/CPUs/Intel/Core_2_Duo_Mobile/T9550_(Socket_P).html Core 2 Duo T9550, http://www.cpu-upgrade.com/CPUs/Intel/Core_2_Duo_Mobile/T9900_(Socket_P).html Core 2 Duo T9900 http://www.cpu-upgrade.com/CPUs/Intel/Core_2_Extreme_Mobile/X9100.html Core 2 Extreme X9100. plz also help with understanding S spec number and stepping
AlHill
You will have to contact the manufacturer of your system and ask what processors are supported by THEIR BIOS. Any upgrade must be SOCKET and BIOS compatible.
Also, the manufacturer can tell you if your system provides sufficient power and cooling for any upgrade.
Personally, with such an old system, I would not bother upgrading it. Spend your time and money on a new/current system and save yourself a lot of frustration. Just my opinion.
Doc
Hello:
Thank you very much to Al Hill for the information provided above.
To sam8832:
I hope the information posted previously was useful for you, because that is the best thing to do when you are trying to do a upgrade, to get in contact directly with the manufacturer of your system, so they can further assist you.
In regard to the s-spec inquiry, on the following link you will be able to see all the information about it:
http://www.intel.com/content/www/us/en/support/processors/000007490.html http://www.intel.com/content/www/us/en/support/processors/000007490.html
And about the question of the stepping, on the following link you will be able to find the explanation:
http://www.intel.com/content/www/us/en/support/processors/000006708.html http://www.intel.com/content/www/us/en/support/processors/000006708.html
Alberto
