Tengo una laptop Latitude E5430 vPro con un procesador i5-3340M y quisiera saber que procesador lo puede sustituir. Ya he revisado la base y si es desmontable el procesador.
You need to ask Dell what processors are compatible WITH THEIR BIOS. Then, you can select from those.
And, your processor may or may not be soldered to the motherboard. If it is soldered, there is nothing you can do.
https://ark.intel.com/content/www/us/en/ark/products/71257/intel-core-i5-3340m-processor-3m-cache-up-to-3-40-ghz.html
Doc
