Hi everybody,
We use a small program under MS-DOS in Windows 7 32-bit. From this new series of Intel processors, some MS-DOS (eg, EDIT) commands do not respond, they are left hanging. We have not had problems with previous generation processors.
Anyone can help on this issue? It may also be related to the new chipset plates?
Thank you very much.
Hi GjParada,
It might be a compatibility issue, the program you are running and your system configuration; but in case you want to we can check the status of your processor, to do that I would suggest you to run the Intel® Processor Diagnostic Tool, please attach the results to your answer.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Hellen.
Thanks for your reply.
The program that we use is very simple, but the problem also occurs with normal DOS commands such as EDIT: they fail to run.
This has happened when we use the new Intel processors, we do not know if this can happen for this reason or some incompatibility Chipset.
Attached reporting IPDT.
--- IPDT x86 - Revision: 3.0.0.25.W
--- IPDT x86 - Start Time: 14/06/2016 11:24:44
Intel(R) spbc Module Test
Module Version: 1.0.7.32b.W
Start Time: Tue Jun 14 11:24:44 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
End Time: Tue Jun 14 11:24:45 2016
Total Time: seconds: 1
Genuine Intel CPU Test
Module Version: 1.0.12.32b.W
Start Time: Tue Jun 14 11:24:45 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 75 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
CPU Frequency Test
Module Version: 1.0.14.32b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
Expected CPU Frequency: 2.70
Detected CPU Frequency: 3.25752
Expected Base Clock: 100
Detected Base Clock: 101.797
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Tue Jun 14 11:24:47 2016
Total Time: seconds: 2
Floating Point Test
Module Version: 1.0.10.32b.W
Start Time: Tue Jun 14 11:24:47 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 475.2
Error: 0
--- Floating Point Test Passed!!!---
End Time: Tue Jun 14 11:24:49 2016
Prime Number Generation Test
Start Time: Tue Jun 14 11:24:49 2016
Test Result - PASS
Operation Per Second: 3.3229e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Tue Jun 14 11:24:51 2016
Cache Test
Start Time: Tue Jun 14 11:24:51 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
End Time: Tue Jun 14 11:24:51 201...
Hi GjParada,
I can see that your processor Intel® Core™ i5-6400 passed all the tests, what was me processor model you used to have to run this program?
Could you please attach the result of the Intel® System Support Utility? in order to get more information about your system configuration.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Can you please tell me the system requirements for that Program?
Hellen.
Hi GjParada,
I would like to know if there is any update regarding the information requested previously.
Hellen.
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
