I have this CPU that seems defective, so far it cant run Small FFT Prime95 for more than 2-3 hours.
Some capacitor/resistor soldering seems broken/melted/burnt:
http://imgur.com/ULkOnPO,pPVXklY,hSCjqZg,osc417e# 0 http://imgur.com/ULkOnPO,pPVXklY,hSCjqZg,osc417e# 0
Can it damage my mobo? Im stil testing it, any advice is welcome.
http://imgur.com/Vyx8Bcm,HVfnZ5K,xONSWWA,aRZadsd,ETmWAA7,iVCH74m,XwHlsiF,vmhxfdu,bBnWdsA,LXU9G96# 0 Some more photos:
http://imgur.com/Vyx8Bcm,HVfnZ5K,xONSWWA,aRZadsd,ETmWAA7,iVCH74m,XwHlsiF,vmhxfdu,bBnWdsA,LXU9G96# 0 http://imgur.com/Vyx8Bcm,HVfnZ5K,xONSWWA,aRZadsd,ETmWAA7,iVCH74m,XwHlsiF,vmhxfdu,bBnWdsA,LXU9G96# 0
Hi Theelguy,
I am sorry to hear you are having problems but let me help you.
I recommend you running the Intel® Processor Diagnostic Tool. This software diagnoses every internal component inside the processor. If the capacitors seem broken/melted/burnt there may be problem with the processor and in fact can damage your board.
You can get the IPDT at the following link:
32 Bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791&keyword=processor+diagnostic&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791&keyword=processor+diagnostic&lang=eng
64 Bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792&keyword=processor+diagnostic&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792&keyword=processor+diagnostic&lang=eng
In case you are in doubt I recommend you contacting your local support for diagnose of the processor or a replacement if necessary.
