Processors
13154 Discussions
Does 1165g7 support MPK?
Gilmour
Hi all,
I recently need to use MPK (Memory Protection Keys) for my experimentation. I want to know if the latest 1165g7 CPU supports MPK.
As far as I know, Xoen CPUs after SkyLake support MPK, and MPK is also supported on the 10th Core desktop CPUs.
If anyone has a laptop with 1165g7 running linux, the command "cat /proc/cpuinfo | grep pku" can check if the CPU supports MPK. If there is any output of this command, it means that it supports MPK.
It is very important for me. If you can provide any help, I would be very grateful. I would be most grateful if you could provide any help.
Alberto_Sykes
Gilmour, Thank you for posting in the Intel® Communities Support.
I can see here in our database that there is an agent already working on your case, so please keep checking that case for possible updates and further assistance on this matter.
Albert R.
