17285 Discussions
Does my CPU have a TPM integrated ?
CaroA
CPU : Intel® Core™ i3-10105F Processor
Motherboard : ASUS PRIME H410M-K R2.0 with NO TPM on it
Updated BIOS (version 2803)
Windows 11 family
TPM is actived in the BIOS but there is no foundable TPM in Windows.
For the more, if i try to re-install Windows by an USB, the installation tool tells me that my PC have not the min requirement for Windows 11. I bought the PC with Windows 11...
Does my CPU have a TPM integrated ? Here are its specifications :
https://www.intel.com/content/www/us/en/products/sku/203474/intel-core-i310105f-processor-6m-cache-up-to-4-40-ghz/specifications.html
Tkx
AlHill
Yes, if enabled in your bios.  Also, update your BIOS.
RUN TPM.MSC and you should see the TPM configuration.
[W10 is today's XP ]
Domin27
Have u found a solution? I have the same exact cpu and motherboard and when I try to change from “Enable Discrete Tpm” to “Enable Firmware Tpm” as soon as I leave BIOS it automatically goes back to “Enable Discrete Tpm” and it’s a infinite loop.
AlHill
@Domin27
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Additionally, ensure your motherboard bios is updated.  Check your TPM settings in your bios.
[Windows 11 is a keystroke logger]
