I recently sent this message to intel tech but the automated response gave me zip:
Entire system freezes intermittently every second or so for about 6 seconds. This happens within an hour from booting the system and with ten-fifteen minutes between them.
I've eliminated the GPU, RAM and HDDs with various stress tests. A program called CPU Stability test by Jouni Vuorio reports my system as unstable, returning an exception from a Tprime module.
My system is (and never has been) overclocked, and the system ambient temperature after 10 hours (5 stress testing) is 39° with the CPU at 38°. The hottest component is the GPU at 46°.
I also swap tested the RAM with another set of the same speed (PC2 6400 2GB) with no change.
Customer_type: End User
Product: Intel(R) Core(TM)2 Duo Desktop Processor
Product_id: 2558 (E8400)
OS: Windows* XP Media Center Edition
Motherboard: Asrock 1600P35 Wifi+
Issue_type: Processor Failure
Bios_version: 1.0
Processor_speed: 3.0GHz
Anyone know what could be causing this? It causes my entire system to slow RIGHT down. Sounds stutter, the mouse moves 2 pixels a minute and then a 6 seconds later it's fine.
![](/skins/images/44D6FBC13D1AFC21DF3F0C7813903D74/responsive_peak/images/icon_anonymous_message.png)
