連結已複製
Provide the following:
What processor model number?
What operating system? Windows 10? If so, what version number? 1809? Lower?
Are you a laptop or desktop?
What is the model number of your system/motherboard and who is the manufacturer?
What Intel graphics do you have?
Doc
Motherboard Product: Z170 PRO GAMING BIOS Version: 3805
Microsoft Windows 10 Pro (64-Bit) Version1809 OS Build10.0.17763
Intel® Core™ i5-6600K CPU @ 3.50GHz
Summary
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i5 @ 3.50GHz 30 °C
Skylake 14nm Technology
RAM
16,0GB Dual-Channel Unknown @ 1072MHz (15-15-15-36)
Motherboard
ASUSTeK COMPUTER INC. Z170 PRO GAMING (LGA1151) 31 °C
Acer XB240H AÒ (1920x1080@144Hz)
BenQ EW2440L (1920x1080@60Hz)
4095MB NVIDIA GeForce GTX 970 (NVIDIA) 61 °C
Storage
465GB Samsung SSD 850 EVO 500GB (SATA (SSD)) 31 °C
1863GB Western Digital WDC WD2003FZEX-00Z4SA0 (SATA ) 36 °C
465GB Western Digital WDC WD50 00LPVT-80G33T2 USB Device (USB (SATA) (SSD)) 31 °C
Optical Drives
HL-DT-ST BD-RE BH10LS30
OPTIARC DVD-ROM DDU1681S
Audio
Sound BlasterX AE-5
when VT is activated i'm getting every 1 or 2 days a BSOD.
similiar to this
Here is what WhoCrashed says:
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
On Mon 29.04.2019 13:40:50 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\042919-6156-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1B3730)
Bugcheck code: 0x133 (0x1, 0x1E00, 0xFFFFF804025E5380, 0x0)
Error: DPC_WATCHDOG_VIOLATION
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x3e8c74)
product: NVIDIA Windows Kernel Mode Driver, Version 430.39
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 430.39
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 430.39 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation DPC_WATCHDOG_VIOLATION
here are the dump files and msinfo32
