Processors
13582 Discussions
High temperatura on Intel i7 - 7700HQ
Marry
Hello community I have ASUS ROG VL 553, this is a gaming laptop that has poor cooling system, I have put up with this and if I play, I use the stock cooler. But I began to notice that even while working with the browser and regular YouTube surfing, it gets warm too. I took apart the laptop, cleaned the cooling system and replaced the thermal grease. Then I try to run the Intel® Processor Diagnostic Tool  to evaluate the intel processor, advice from post https://community.intel.com/t5/Processors/Hello-I-have-i5-8400-processor-for-a-year-and-a-half-and-I/m-p/728902#M44011, I test proccessor with very simple site finding in the google -  https://1x-rate.com/,   and have about 65c, I don't understand why Proc such warm. I'm going to take it to a SC, but I decided to write to the community first.
Does anyone have any ideas?
AlHill
Sounds like a poorly designed laptop.  Have you complained to ASUS?
Doc
Marry
Yes, they advised using their software to increase the cooler speed ... I use it when I play games and it makes a lot of noise, I will try to run tests with the fan turned on as much as possible, but I hope to solve this problem somehow, work in such a noise is simply not possible ...
