Processors
14784 Discussions
How to find the FCLGA2011(for Ivy Bridge EP, like Xeon E5-2637 v2) socket datasheet
WWill8
Maybe there're several versions of LGA2011 for different processors. So I wanna know the exact name of the socket for Xeon E5-2637 v2, Ivy Bridge EP and where to download its datasheet. Thank you very much for your kind help! I've googled for days, hah...
AlHill
The specs for your processor are here: http://ark.intel.com/products/75792/Intel-Xeon-Processor-E5-2637-v2-15M-Cache-3_50-GHz Intel® Xeon® Processor E5-2637 v2 (15M Cache, 3.50 GHz) Specifications
The socket is FCLGA2011.
Doc
WWill8
Thank you very much, Mr. Hill. Since I'm to work on the motherboard design, simple specifications are not enough. I wanna get the data sheet of E5-2637 v2 for pin map. Is there any open document? Please kindly help me.
AlHill
All I can find at this point are these documents:
http://www.intel.la/content/www/xl/es/processors/core/core-i7-lga-2011-datasheet-vol-1.html Intel® Core™ i7 Processor Family LGA-2011 Socket Datasheet, Vol. 1
http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-1600-2600-vol-1-datasheet.html Intel® Xeon® Processor E5-1600/2600/4600: Datasheet Vol. 1
http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-1600-2600-vol-2-datasheet.html Intel® Xeon® Processor E5-1600/2600/4600: Datasheet Vol. 2
http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-family-spec-update.html Intel® Xeon® Processor E5 Family: Spec Update
If these do not help, perhaps one of the Intel support staff can provide the links you need.
Doc
WWill8
Thank you very much, Al. That helps a lot, although I'm afraid it's not very direct and exact.
Hi Williamkuo,
In case you need more information you can get in contact with the developers in this link, follow the steps below
http://www.intel.com/content/www/us/en/embedded/embedded-design-center.html http://www.intel.com/content/www/us/en/embedded/embedded-design-center.html
Once you access it,
  • Scroll down until they see the title "Explore the Resource & Design Center"
  • Select Design Assistance and fill out the information required
  • Select Account Support
  • Go to the right-hand side of the screen
  • Select create an account to enroll with us
  • Request to upgrade to privileged to be able to apply for a Privileged account which gains you access to additional Intel® confidential collateral, tools, and services.
A Corporate Non-Disclosure Agreement (CNDA) is required and the review process may take several days.
Hellen.
Hi Williamkuo,
Thought I would just check in and find out if the information provided helps you.
Hellen.
