16795 Discussions
How to utilize both P-core and E-core on my Intel i9 12900K for best performance?
Rohan_V
My intel i9 12900k processor only utilizes 8 E-core threads out of all 24 available threads while using a software called Advisor 5.3 by Sarine Technologies on windows 10. It is a 3D diamond planning software. I also have intel i7 11700F which uses all 16 threads while using this same software. So on my i7 processor it utilizes 100% of CPU capacity. On the other hand on my i9 processor is utilizing only 40% of the CPU capacity. It only uses last 8 threads (CPU 16 to CPU 23 on resource monitor) which I'm assuming is E-core only. All the other cores i.e. CPU 0 to CPU 15 are showing parked. So basically my i7 processor is doing the task quicker than i9. I only purchased this very costly i9 12th gen processor to do my work faster but I am not getting satisfying results.
How can I configure my processor either directly or through bios to run faster?
Is there any way to utilize those remaining cores (or threads) to get 100% CPU utilization?
I have attached some screen shots here.
Please help me regarding this.
Thank you.
DeividA_Intel
Hello Rohan_V,
Thank you for posting on the Intel® communities. I understand you want all your threads while using Advisor.
I would like to let you know that sometimes, multiple instructions are completed in a single clock cycle; in other cases, one instruction might be handled over multiple clock cycles. Since different CPU designs handle instructions differently, it’s best to compare clock speeds within the same CPU brand and generation.
For example, a CPU with a higher clock speed from five years ago might be outperformed by a new CPU with a lower clock speed, as the newer architecture deals with instructions more efficiently.
Recent features like the Intel® Thread Director allow the latest generation Intel processors to intelligently distribute workloads to multiple cores. That’s one reason why newer processors often outperform older ones on benchmark tests even when they have similar clock speeds.
Bear in mind that the operating system chooses what core and threads use and when to enable them. You can check more information at the following links:
1. What Is Clock Speed?: https://www.intel.com/content/www/us/en/gaming/resources/cpu-clock-speed.html#:~:text=What%20Does%20Turbo%20Frequency%20Mean%3F
2. Technical Product Specification: https://www.intel.com/content/www/us/en/products/docs/processors/core/core-technical-resources.html
Check 12th Generation Intel® Core™ Processor Family> Volume 1> Processor IA Core Power Management> page 60.
Deivid A.
DeividA_Intel
Hello Rohan_V,
I am following up to check if you need further assistance and confirm if you still have questions related to the P-Cores and E-Cores.
Please, let me know if you need my help.
Deivid A.
Rohan_V
Thank you very much DeividA.
I have one more question,
Is it okay if I disable all the E-cores and only use my software on P-core to boost up my performance?
Will it affect the operation of the CPU ?
DeividA_Intel
Hello Rohan_V,
Thanks for your response. In this case, it is not recommended to disable the E-cores as this may negatively impact system performance and at least one E-core will remain enabled (not all of them can be disabled).
If you would like to proceed, you can use the following steps:
  1. Access the system BIOS.
  2. Go to the "Power, Performance, and Cooling" menu.
  3. Set "External Ambient Temperature -Tolerance" to "User Defined".
  4. Click on Performance.
  5. Click on Processor
  6. Set all Active Atom Cores to 1
Deivid A.
DeividA_Intel
Hello Rohan_V,
I am following up to confirm if you proceeded to disable the E-Cores or if did not do it. I would like to know if you need further assistance.
I will be waiting for your confirmation.
Deivid A.
DeividA_Intel
Hello Rohan_V,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
